Quantcast Trouble with a high millage 5.8 - Ford Truck Club Forum
Old February 3rd, 2016, 04:06 PM
94wind351's Avatar
94wind351 94wind351 is offline
Cool Trouble with a high millage 5.8
I have had my 1994 250 5.8 for 12 years and have never had any trouble with it that I couldn't figure out on my own. It has recently decided not to run real well. It will run great and with no notice start to crawl and eventually stall. I have replaced the plugs, wires, cap, rotor, distributor, ignition control module, ignition coil and fuel filter it runs better now and I haven't had it stall in awhile however I haven't driven very far distance do to a newly found trust issue with my truck it still spudders out a little bit at idle and low RPM any ideas? could the timing be off just enough to cause the rough idle? seems I can turn the distributor enough to either have a good idle in park or neutral or In drive and reverse can't seem to find the medium. Please help. I'm not sure if I'm posting in the right location or not, new to site and excited to give and receive information with y'all.
Old January 22nd, 2017, 01:37 PM
rAzkid's Avatar
rAzkid rAzkid is offline
Liked 2 Times in 2 Posts
I know this is an old thread but this might help someone else. Disconnect the battery, put a socket with breaker bar on the crankshaft damper center bolt and remove the distributor cap. Rock the breaker bar back and forth while watching the distributor rotor. If the timing chain isn't stretched then the rotor should move as soon as the breaker bar moves. With a high mileage engine the timing chain is probably stretched quite a bit and you will notice the breaker bar will move without the rotor moving. You didn't say how many miles are on the engine but a timing chain may be needed in order to correct the valve and ignition timing.
harrison28 (January 23rd, 2017)
Old January 23rd, 2017, 06:49 AM
^^^ good idea
94wind351 , anavaho , cdv , glc , harrison28 , JSoko , Lostin90s , MADV79 , rAzkid , Rebelrider60 , skatebowd
Trouble with a high millage 5.8 94wind351 1992-1997 Ford F250 | F350
0 February 2nd, 2016 09:21 PM
slugish/no power/rough idle/bad gas millage judd94 1973-1991 Ford F150
4 January 14th, 2016 10:00 PM
Need Help With Trouble Codes MyNameHere 1992-1996 Ford F150
1 January 5th, 2015 04:11 PM
help trouble code 171 & 172 rpez4u New Member Introductions 2 July 16th, 2014 08:37 AM
trans trouble geroid 1948-1983 Ford F100
2 May 1st, 2014 08:38 AM
high , millage , trouble
