May 24th, 2015, 12:56 PM
351W Swap
Alright, it's been a while people. I'm starting my 351W swap. I currently have an EFI 5.0 in my 91 F150. I switching to carb. So here's what i'm doing:
Block: .060 Over, hyper pistons, 9.2-9.3 CR
Heads: Stock, replacing valves and valve springs 1.250 bind height and
230lb/in pressure rate and home port and polish
Camshaft: Going Lunati Cam specs are as follows Duration @ .050 219/227
Lift .499 .522 with a 112 LSA
Carb: Holley 4150 600cfm with vac secondaries
Intake: Edelbrock performer with lokar kickdown cable
Exhaust: Running Shorty headers with Bassani Y-Pipe. I don't feel like messing with LT and 4wd, I also already have the headers and ypipe so it saves money and the marginal gain of LT isn't worth the headache.
For the fuel system i'm keeping my stock pump in the tank but getting a regulator with return so I can dial it down to 6PSI. I haven't decided on an air cleaner yet, I'm not sure what kind of clearance i'll have to work with. I'm going to go with Procomp for my electronics. Any advice on jetting for the carb would be appreciated, the carb currently has 69 primaries and 6.5hg power valve. I'll upload pictures as I go. I'm hoping to have all this done by the time monsoon season hits in Tucson.
Reason: Gotta throw exhaust in there.
May 28th, 2015, 09:44 PM
Update, found a set of 289 heads for $350 on craiglist. They have 1.94 intake valves and 1.60 exhaust valves. They have also been reground for chevy springs and come with all new hardware. They have also been decked and ported and polished. They have closed chambers and CC out to 58cc combustion chambers. No the most ideal head, but they cost less than what I was gonna do to my stock heads and will perform better.
June 2nd, 2015, 06:44 PM
Update as well as a request for help. Decided to drop the Lunati cam and go Comp cams 35-235-3 Cam. Int .477 Exhaust .493 Duration at .050 210 and 218 respectively. The issue i'm running into is valve lift. I'm looking at valve springs and it would seem that none have an adequately low coil bind. Here's my math and hopefully it's wrong. 0.493x1.6(rocker ratio)= .787. Add .060 for a safety margin and that brings my needs to .847. If my springs installed height is 1.7" I need it's coild bind to be around .860. Can anyone help me? I've emailed compcams to see if they can provide guidance but i'm at a loss.
June 3rd, 2015, 08:24 PM
So, when looking at the cam specs I totally missed the section that said lobe lift. Their valve lift figure is calculated using a 1.6 rocker ration. Now all I have to do is figure out my current springs coil bind and the seat diameter that these heads will accommodate.
June 9th, 2015, 09:56 PM
So the seats will accommodate up to 1 3/8" diameter. Current valve springs have a 1.250" OD, and it seems that most springs above this have an installed height of 1.8 and usually a coil bind commensurate with the increased height. I found some springs that have a seat pressure of 110lbs at 1.7 with an OD of 1.250 and a rate of 280 lbs/in which my existing hardware will accommodate.These should also help the engine idle well. I also looked a bit more into calculating compression ratios. I stumbled upon compression height and found out that to achieve a lower CR, that pistons i'm using have a .020" lowered compression height. This increases my piston to deck clearance and drops my dynamic CR to 7.47 and static to 9.5, which should handle pump gas just fine.
June 9th, 2015, 10:04 PM
Looking at a few similar builds, this engine is going to be torquey as hell starting around 2k rpm. Found a guy with a similar build and his engine put out over 400ftlbs from 2000-3500.
I'll have .25 more compression as well as better flowing heads and more cam. Will a stock aod handle this power? Or am I just gonna have to wait till it shreds it and tell my wife I need to build a beefier tranny?
June 26th, 2015, 04:58 AM
What brand is your exhaust system?
June 26th, 2015, 06:31 PM
Exhaust
I have flowtek shorty headers (I think) with a Bassani Y-Pipe into a dynomax super turbo muffler. The CAT is 3" and the muffler is 3" in with dual 2.5" out, I bent my own tubing and cut it resulting in the exhaust coming out just in front of the rear passenger tire. It's SUPER throaty, idles insanely queit but as soon as I accelerate it can set off some of the more sensitive car alarms. Overall it's too loud for my liking, but when I run the rpm's up at idle it sounds MEAN. Under load just loud and throaty. These are pretty much what I have but about twice as expensive as when I bought them.
July 9th, 2015, 09:17 PM
So I got a great deal on 30lb injectors with a calibrated MAF. I'm ditching the carb and just doing a MAF swap. It'll cost about the same all said and done and emissions won't be an issue. If anyone has a computer or donor wiring harness please hit me up if your selling.
September 4th, 2015, 06:00 PM
Update! So I found a guy on a forum that I was able to purchase an A9P as well as a complete engine harness(Injector harness and MAF included). Right now all i'm waiting on is income to permit me to buy the rebuild kit for my engine as well as the new parts i'm putting on it.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 18
3rd-coast-thumper
91klunkr
ASwaff400
Atate5
Booba5185
Cass
FXRS
glc
gwfan
harrison28
IrishKRO
JSoko
ncranchero
RichB
RKTDR
Russo2
Thesmanman
unclebeer
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
351w engine swap thread
ASwaff400 |
Garage Talk: Engine & Drivetrain |
5 |
July 4th, 2015 04:11 PM |
351w Heads
BigBlue79 |
11 |
February 17th, 2015 08:54 AM |
351W Build
IrishKRO |
28 |
April 16th, 2014 08:27 PM |
351w vs 351c 4v/2v
RoadHawg |
1992-1996 Ford F150
14 |
November 23rd, 2013 09:23 AM |
84-87 351W H.O. Information
nflfreak43 |
1973-1991 Ford F150
3 |
March 5th, 2013 12:07 AM |
