Quantcast bad roaring from the front end - Ford Truck Club Forum
Old May 9th, 2011, 12:31 AM
nismo972's Avatar
nismo972 nismo972 is offline
Default bad roaring from the front end
Hey guys got a question about front ends. I have this roaring or grinding sound coming from the front of the truck. It only appears when the wheel is straight and the truck is in motion. A few weeks back i was hauling some storm debris and the truck started severely shaking for a couple hundred feet and then calmed down. Any ideas????
Old May 9th, 2011, 07:19 AM
Images: 622
Liked 182 Times in 164 Posts
is your Truck 4 wheel drive ?
Old May 9th, 2011, 09:22 AM
I'm going to make a guess, if its a 4x4, it may be the IWE solenoid. Someone with that gen of truck (and more time than I have right now) should be able to explain it and maybe show more about it.
Old May 9th, 2011, 09:30 AM
TedC's Avatar
TedC TedC is offline
Images: 151
does it sound like "Ice in a blender?" It should occur between 30-40 mph coasting (if its the same as mine)
There are two main causes of this: 2007 Fords had a recall because the IWE selenoid was missing a shroud - causing water from the hood to infiltrate the electronics and cause shorts. 2008 models have the shroud already.
The second cause is a vacuum leak somewhere between the hubs and the solenoid - causing intermittent engagement of the 4wd
Also - read this thread for more info: http://www.fordtruckclub.net/forum/s...ead.php?t=4028
Old May 9th, 2011, 02:33 PM
Scotts Black FX4's Avatar
Images: 40
Didnt Matt also have this issue ?? (RedHot150)
Old May 9th, 2011, 03:31 PM
Images: 622
no he was'nt allowed to use the blender
Old May 9th, 2011, 03:34 PM
Images: 622
I think this is nismo's Truck 2WD
http://www.fordtruckclub.net/forum/g...ment.php?id=49
dont drive anywhere until you check the following, you could do more harm and end up stuck somewhere and having to $pend more $$$
Jack up the front end and see if you have any movement in the wheel up and down could be a wheel bearing
remove wheel, spin hub and check for brake noise / wear
if you do need to remove the hub for repairs get back with us
crawl underneath (jack stands) and check the steering componets "I doubt this is the cause"
Old May 9th, 2011, 05:20 PM
Images: 40
Hahaha....You do recall when he had it towed tho right ?
Old May 10th, 2011, 07:40 AM
Images: 622
he and Vinny always had problems must be the Pennsylvania air
but I belive it was transmission issues for Matt
Old May 10th, 2011, 11:24 AM
Yeah, I remember. Think it was trans related.
bobkyle2 , DoubleDee , HawaiianF150 , JSoko , Klitch , marmaduke , minnehonk , nine5flareside , nismo972 , rebelangal83 , russ94 , Russo2 , sbellinghausen , Scotts Black FX4 , sonny , TedC , whitesleeper
front axle swaP 1stockpstroke 1992-1997 Ford F250 | F350
9 August 16th, 2014 05:39 PM
Front Tank issues tity04 1992-1996 Ford F150
15 December 4th, 2011 09:48 PM
Hellwig Products Front Sway Bar Bates88 Garage Talk: Brakes & Suspension 1 August 4th, 2010 07:42 PM
Front receiver installation Hwyman 2004-2008 Ford F150
2 June 23rd, 2010 09:58 PM
Need ideas for a new front grill 2004FX4F150 2004-2008 Ford F150
35 November 30th, 2009 01:06 AM
bad , end , front , roaring
