Quantcast vacuum diagram - Ford Truck Club Forum
Old February 6th, 2015, 05:28 AM
craig's Avatar
craig craig is offline
Default vacuum diagram
I hope some one can help me. I have a 1978 Ford F150 with a 4.9L engine with a carter 1 barrel YFA carburetor, with auto transmission. This truck is a non-catalyst in engine family 300 HMOC. I believe the emission code is DTE-9C485-BA and in the corner of sticker it has D-002. This truck was built in Norfolk Virginia in January 1978, I check vin number for all relevant information.
What I am looking for is the vacuum schematic, diagram. Previous owner removed all vacuum lines except distributer advance and power brake. Truck run bad I need to fix vacuum system any help would be appreciated.
I have checked out fuel tank for return line from a charcoal canister or purge valve, fuel tank is not equipped for a return line. I have attached the only diagram I have found so far, but it's got the return line to fuel tank. I have also upload a picture of my carburetor and vehicle emission sticker.
Any help would be greatly appreciated
Click image for larger version
ID:	1096   Click image for larger version
Name:	78 vacuum diagram.jpg
ID:	1097   Click image for larger version
(View-All Members who have read this thread : 18
78_Gray_CS , craig , Damienr6 , Desert dog , F100Chief , FXRS , glc , Hemifish , jake3247 , lostcause , mefreeman , ncranchero , Ozzie , Pcbauer , Russo2 , Scorekeeper58 , smashbear , Steve
LOW VACUUM EDMAN 1987-1991 Ford F250 | F350
2 January 18th, 2015 10:10 AM
Vacuum and Emissions Tyler.purrington 1987-1991 Ford Bronco
15 September 18th, 2013 10:05 AM
Vacuum Line diagram GBronco 1980-1986 Ford Bronco
9 July 13th, 2013 12:25 PM
need vacume line routing diagram for 91 f350 7.5l engine w/auto trans charlie Garage Talk: Shop Class 101 1 March 5th, 2011 09:39 PM
95 Ford F-150 Wiring diagram? PAINTER78 1992-1996 Ford F150
1 January 21st, 2011 10:32 PM
diagram , vacuum , vacuum diagram 1978 4.9l
