Quantcast front axle swaP - Ford Truck Club Forum
Old April 9th, 2011, 02:44 AM
1stockpstroke's Avatar
1stockpstroke 1stockpstroke is offline
Default front axle swaP
i want to change to a straight axle what should i go with and how hard is it?
Old April 9th, 2011, 06:13 AM
whitesleeper's Avatar
Default The swap
OK what do you have now year model gear ratio trans type
im guessing IFS on leaf springs ?
Old April 9th, 2011, 02:27 PM
i have a 95 250 7.3 and yes it has the ifs with leaf springs i have problems with the frontend now so im just going to do the swap im on the hunt for the stuff i need now. i know theres a few i can just drop the old shit and bolt the new in but not sure what year or axle i need to get im over this poop frontend
Old April 9th, 2011, 02:33 PM
oh and the tranny is a e4od
Old April 10th, 2011, 09:10 AM
The most common SAS axles are the dana 44 and the dana 60. For us to suggest an axle to you, you have to tell us what you plan on doing with your truck! I am currently working on swapping a d44 into my truck. ASwaff400 already completed his d44 swap and then there is also Klitch and Dixie who have done swaps as well.
What rear axle do you have, an 8.8? What is your lug pattern and spacing? That will also be something to think about when swapping axles.
Old April 10th, 2011, 01:51 PM
I think on that year truck a D44 would be much more direct swap, unless you want to do the matching rear as well.
Old April 10th, 2011, 06:54 PM
Default solid axle
do to the weight of the truck you want to stay with a DANA 60 ..
If you arent in a hurry and keep checking around you can find one that came out of a 87-97 f 350 . THE 87-88-89 f350 all had the heavy duty version .And if you find one that has the springs on it that will be a PLUS for the simple fact that to put a solid axle under your truck you WILL need springs . That will give you a instant 5 inches of lift ..
Hope this helps you any others ? we are just a click away
Old April 10th, 2011, 07:26 PM
4x4x4's Avatar
4x4x4 4x4x4 is offline
I would go with a dana 60 from a 87-97 f-350. Should pretty much bolt in and you will have the correct bolt pattern for your wheels. I would think you will be able to use the springs that are in your truck now. I cant see the f350 one being much if any different
Old April 10th, 2011, 09:33 PM
Ah my bad, thought this was another 1/2 ton truck!
Yeah dont listen to what I said before, go grab one of them D60's and get er done.
Old August 16th, 2014, 05:39 PM
leojr's Avatar
leojr leojr is offline
I think your 95 has the newer brakes...do you remove your calipers with two 13mm bolts? If so, you will want a donor axle from a 95 or newer. This lets you service your calipers if needed and add longer brake lines now so you don't have to do it during the swap.
Don't get side tracked by conversations about king pin and ball joints unless you are going to do serious off roading with it.
My thread linked in my signature may be of help but there are some other really good threads out there too.
96 F250 4x4 PSD auto CCSB
D60 axle swap with F350 front springs
SD (B code) rear springs and 4" factory F350 blocks
Explorer grab handles
Remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread
Link to my OBS air vent R&R thread
1stockpstroke , 4x4x4 , 96 crewab , anthony.armeli , ASwaff400 , BigBlue79 , BIGCOUNTRY , blackdog714 , blue lantern , brads93bronco , Burton7.3 , Colesburg Hood , DoubleDee , drvshft , farmer11 , FORD TRUCK FAN , glc , Googan , HARLEY589 , jay98neon , johnnyb1 , jpracing , JSoko , Klitch , leojr , Lostin90s , michaelsnodgrass18 , mr wu , Mtgoat , nine5flareside , nolla , ondgas , Russo2 , Scott12345 , SlydinClyde , steve5055 , Stewy 39 , suburbanhotrod , whitesleeper , xXBLEED-BLUE460Xx
1995 f-150 Dana 44 SAS - Solid Axle Swap fbm1344t Garage Talk: Solid Axle Swaps 46 September 16th, 2014 08:10 PM
Front Tank issues tity04 1992-1996 Ford F150
15 December 4th, 2011 09:48 PM
solid axle swap The-LI-Redneck Garage Talk: Solid Axle Swaps 12 August 30th, 2010 12:00 PM
Best axle for your swap, and how to identify it. DIXIE FIX Garage Talk: Brakes & Suspension 15 March 16th, 2010 07:51 AM
axle , front , swap
