Quantcast stalling issue 1987 4.9 - Ford Truck Club Forum
Old December 17th, 2015, 12:33 AM
yodanathan's Avatar
yodanathan yodanathan is offline
Default stalling issue 1987 4.9
New here and looking for advice or any help. My truck is having idle issues. starts right up but when it starts it shoots up to 1700-2000 rpm and slowing dies til full stall in a matter of 10-15 sec. If I gas it and keep it at those rpms or higher it will keep going until I let off the throttle. Ive replaced many parts including the tps, idle solenoid, egr, eec relay, fuel pump relay, air and coolant temp sensors,air filter, spark plugs, ign coil, tank sending unit, and more. vacuum is at 20 in-hg which Ive read is normal. I pulled engine codes 23 and 67. 23 is for throttle too high or tps out of range and 67 is the clutch pedal position issue. I have disconnected the battery to clear the computer as well but codes come back. I tested the tps and got good ground, power, and smooth voltage increase as I opened the throttle. good ground to the pcm as well. I pulled the pcm and all the capacitors are looking good with no leaks or burns. checked the fuse box. both fuel pumps engage when key is on and relays click. My last idea is the pickup coil? would this cause a 23 code?
Old December 26th, 2017, 12:53 PM
vjsimone's Avatar
vjsimone vjsimone is offline
Did you ever get this fixed ?
bigcreek , Bog01dram , glc , harleydog661 , harrison28 , JSoko , kcwheeler , rcorey , sweetcarcare , vjsimone , yodanathan
1987 f-150 stalling and cutting out. gillygo505 1973-1991 Ford F150
0 July 7th, 2014 10:47 PM
97 f150 stalling issue. hulk8710 1997-2003 Ford F150
2 May 8th, 2014 10:08 PM
86 f150 stalling and backfire. ilovefords31 1973-1991 Ford F150
0 October 31st, 2013 10:47 AM
RPM issue & starting issue rusty001 1992-1996 Ford F150
1 December 2nd, 2012 08:00 PM
new member - 1987 F150 Stall Issue kenny48 1973-1991 Ford F150
11 February 5th, 2012 12:15 AM
1987 , issue , stalling
