Quantcast 2000 4x4 limited - Page 4 - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Excursion
  #31
Old October 20th, 2015, 09:45 AM
had a piece of high temp rubber tubing that was close to the I.D. of the remaining piece of dip stick tube. threaded a stainless bolt into the inside of the rubber tubing. used tie wire around the bolt head to the dip stick mounting bolt to keep in place. new tube should be in tomorrow when i get home from work. checked out my temporary fix last night,...was holding up pretty good.
  #32
Old December 2nd, 2015, 02:43 PM
The time has come. By the end of December the beast will be gone. I'm sending it on to it's next life. Gotta buddy who has a 79 F100 he wants to unload. He's been wanting my Excursion to make a weekend toy. Also got my eyes on a 78 pick up that's possible coming up for sale soon. Either way,....it's got to go. My little girls aren't very happy when we talk about getting rid of it. It's the first vehicle they can remember.
  #33
Old December 4th, 2015, 09:14 PM
GET THE TRUCK !!!!
  #34
Old December 7th, 2015, 10:54 AM
yep,...that's the plan. as soon as we get past the holidays and moving into the new house.
  #35
Old December 9th, 2015, 09:13 AM
I hate moving
good luck
  #36
Old January 12th, 2016, 02:22 PM
well, got all moved in to the new joint. just dropped the excursion off to have some work done. having new valve stem seals put in. gonna check and see if the guides are worn also,....(probably are) and have them replaced. new pinion bearing and seal and axle seals for the rear. gonna get some new shocks when i get it back as the fronts are all but shot. might as well change them all.
  #37
Old January 12th, 2016, 07:58 PM
I know it's a relief with the move over
  #38
Old March 1st, 2016, 10:57 AM
after 217k on the beast,...it finally spit out it's first spark plug. the worst one too,....back of passenger side. broke the hold down tab on the coil pack also. picked up an american made Denso OEM coil pack for $34 and a $60 Canadian made (at least it wasn't Taiwan made) tap kit for Ford aluminum heads and had it back on the road in 20 minutes and 1 cold beer. think i'm gonna buy a couple more of those kits and keep them in the glove box, that way i'll be ready if WHEN it happens again, no matter where i'm at.
  #39
Old March 1st, 2016, 11:15 AM
They won't blow out if you use a torque wrench - 28 ft/lb. Motorcraft plugs and NO antiseize recommended.
The only inserts that last are Timesert and Lock N Stitch.
  #40
Old March 2nd, 2016, 08:19 AM
yes, Timeserts are all we use on old Harleys
I guess I got lost, on the blown plug
I thought the engine was a 302 disguised as a 351
« just bought an ex | There is no next thread »
ASwaff400 , glc , gwfan , harrison28 , JSoko , Klitch , skatebowd
2000 F250 haunting Cothrom 1999-2007 Ford F250 | F350
3 March 5th, 2012 06:09 PM
Fathers 2000 PSD Klitch 1999-2007 Ford F250 | F350
6 November 15th, 2011 11:32 PM
How to Change the EGR on a 2000 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:33 AM
2000 f150 3rd member * Terry G. 1997-2003 Ford F150
7 June 16th, 2011 08:55 AM
Limited sale on leupold scopes DoubleDee General Discussion
1 May 27th, 2011 05:27 PM
2000 , 4x4 , limited
