Quantcast P401 and p1131 - Ford Truck Club Forum
Old January 4th, 2011, 11:42 PM
BigTrouble's Avatar
BigTrouble BigTrouble is offline
Default P401 and p1131
ok I have changed the egr valve and dpfe last year still throwing the p0401 code I also cleaned the throttle body. what could still be making it throw the p0401.
this one has me a little confused. p1131 is another code I'm getting and everywhere I have been reading says it could be the mas air flow sensor needing to be cleaned. I was thinking it was the bank 1 sensor 1 that the o2 sensor was gone but would like clarification on this code.
Old January 5th, 2011, 12:15 AM
Clean the MAF if you have not recently
When cleaning for the EGR code, did you check the elbow after the TB to make sure the ports after the egr were clean too and not blocked?
Old January 5th, 2011, 12:49 AM
BigTrouble's Avatar
didn't see any ports after the egr ports
Old January 5th, 2011, 04:11 AM
I meant where the EGR mounts to that elbow, the ports that go inside from that point. If I have to I'll find pictures
Old January 6th, 2011, 09:31 PM
BigTrouble's Avatar
the tube? my truck has the 5.4 so I'm not understanding what your talking about and if you have a pic I would be able to know more
Old January 6th, 2011, 11:02 PM
real quick search found this.
Old January 22nd, 2011, 08:48 PM
BigTrouble's Avatar
oh yea I cleaned them they wasn't that dirty to begin with I cleaned the mass air flow sensor but I think it needs to be replaced. after cleaning it helped for a couple of days but has been doing the same thing
Old January 23rd, 2011, 09:02 AM
torkum's Avatar
torkum torkum is offline
Have you seen the freeze frame from the P1131 code? Is it picking up at idle or higher RPM? I would be looking for a vacuum leak
Old February 8th, 2011, 08:45 PM
BigTrouble's Avatar
I don't have a reader that will do that
Old March 2nd, 2011, 06:25 AM
imhsar's Avatar
imhsar imhsar is offline
If it is creating so much of problem and you are not able to solve it, so please consult with your mechanics.
adamfx4 , ASwaff400 , Bastien , BigT67 , BigTrouble , cecil281 , cowboy , DavidS827 , imhsar , Jordan , JSoko , Klitch , marmaduke , nflfreak43 , nine5flareside , pete59edsel , torkum , whitesleeper , xxpaintballxx
p1131 , p401
