Quantcast Gear ratios - Ford Truck Club Forum
Old May 20th, 2012, 12:12 PM
ktm126's Avatar
ktm126 ktm126 is offline
Images: 30
Default Gear ratios
Hey I was wondering if I have 4.10 gears in the back and had 4.09's in the front can i replace my front current 4.09's with 4.10's without messing anything up?
Old May 20th, 2012, 01:15 PM
They're the samething, the newer F150's(about 83-96) had a optional gear ratio of 3.55, it if was 4x4 it had a 3.54 gear in the front. If you can(D60 front axle) no it shouldn't mess anything up, the only reason it has 4.09's is there wasn't a 4.10 front D60 gear made in 1974.
Old May 20th, 2012, 01:35 PM
ktm126's Avatar
Images: 30
When I was looking around on the internet to find out if I had dana 60's or dana 44's everything I saw was telling me I had a D44 in the front and a D60 in the rear. The diff covers are different so my guess is that somebody swapped the axles and that I have a D44 in the front a D60 in the rear.So if I were to put a dana 44 with 4.10 gears in it would I mess anything up?what do I need to do to Identify everything to be 100% sure what i got?
Thanks,
Will
Old May 20th, 2012, 01:53 PM
Ford did have a Dana 44HD axle that was 8 lug in they're 3/4 ton's so it's possible it came with a D44HD from the factory.
No, IMO it wouldn't mess anything up, having the same gear ratio's in the front and front is perfect. If I had the extra money and was in you're shoes, I'd also install either a locker or a LSD unit in the front axle when I swapped gears.
Were you ever able to get the stubborn piece off of your axle?
Old May 21st, 2012, 01:30 AM
In simple terms no. You are fine.
Ford used gear ratios one off from another, for whatever stupid reason. Gears need to be matched in a 4x4 between the two axles, but there is a slight bit of room for err there. Don't try to use 3.08's and 4.56's though..
Old May 21st, 2012, 12:19 PM
ktm126's Avatar
Images: 30
thanks for the help.After I got your post I found a guy on CL with a axle assemby complete hub to hub and I ended up just getting that for a steal.
Thanks
Will
ASwaff400 , beast428 , BigBlue79 , Booba5185 , F150GT , farmerdj96 , JSoko , ktm126 , nine5flareside , Ridgerunner , Russo2
Top Gear on History Channel DoubleDee FTC Media Center
3 August 9th, 2011 01:59 PM
tire and gear ratio xxpaintballxx Garage Talk: Wheels & Tires 5 June 14th, 2011 03:09 PM
Gear oil. Russo2 Garage Talk: Paint & Detailing 1 June 10th, 2011 01:34 PM
What gear ratios could be had in a F350 4x4 with 5.4 and manual 6spd? Lostin90s 2008-2010 Ford F250 | F350
7 February 23rd, 2010 03:50 PM
Gear Ratios and Size Scotts Black FX4 2004-2008 Ford F150
22 July 18th, 2009 03:06 AM
gear , ratios
