Quantcast New toy f250 2wd - Ford Truck Club Forum
Old July 9th, 2013, 02:12 PM
Tr00b's Avatar
Tr00b Tr00b is offline
Default New toy f250 2wd
I got this truck for a steal at an auction. Says its a 77 on the doorjamb i think and its rusty but it drives and is pretty solid yet. I didn't make it home fuel line plugged real bad. 351m an auto and a Dana 60.
So far plans are to get it running and use it as is... And use it for a template for wiring and assembling my 1974 highboy with a bumpside cab project.
Future plans are 4bbl intake and carb for fuel mileage and power. Then Detroit locker and AT tires. If I end up in a better financial situation.... take advantage of 8:1 compression and throw a turbo on it.
ID:	937   Click image for larger version
ID:	938   Click image for larger version
Old July 9th, 2013, 07:38 PM
Always loved that body style. Think you'll ever fix the rust?
Old July 9th, 2013, 09:51 PM
i also like that body style i would work on rust after i got it running
Old July 11th, 2013, 11:40 PM
Tr00b's Avatar
Hey thanks guys, I really like the way this truck looks too, hoping that I can save it. We will see how tired I get of body work while I do the cab swap on my 74 though, plenty to do there.
I did some more research. I have a 23 axle code which is 3.31 gear ratio Dana 61 axle. I was pretty disappointed by that, will make it MUCH more expensive to do fun stuff with. But it will make sense gas mileage wise.
The engine runs like garbage while its cold and it won't idle. I cleaned up the ignition and have been running the truck every day but it doesn't seem to get better. My highboy doesn't seem to have that problem. I can also hear a sucking noise but haven't found the vac leak yet.
So far, the list to get it going down the road:
Gas tank, gas line and filter gotten in order...
The steel rear gas tank is junk and leaks real bad. There were two plastic side tanks, but they are strapped to rusted out pieces of body sheet metal on the bed up by the cab, and the previous owner quit using them presumably because the body sheet metal rusted out and he lost the drivers side tank (it tore the sheetmetal of the bedside and pooped out). I'll have to repair the passenger side chunk of sheet metal to use the existing plastic side tank, or relocate it somewhere else.
Rebush the front end suspension
The bushings on the radius arm on the drivers side are totally gone. I also think the kingpin is bad on the drivers side, i can rock the wheel back and forth a bit, but it might be bushing play on the radius arm. Anybody know what parts I should replace while I am in there? Looking like I gotta take apart a ton of stuff to get the bushings in. This is why the brakes pulled to one side, lol...
Fix the choke
They converted to a manual choke the way most people would butcher a pig with a lawnmower. They ****ed it up so bad the choke doesn't even work if you have the air cleaner off and try and push it shut. If anyone knows where I can find a theory of operation on this, would be much appreciated. Instead of the temperature spring like my 74 with the 360fe, it has a vacuum actuator and a bunch of stuff I haven't seen before, pretty different than my 1974.
Windshield wipers, oil change, air filter, rearview mirror glued back in.
Should be good to roll after that.
Old July 13th, 2013, 04:30 PM
Tr00b's Avatar
I messed around with the fuel lines some more, cleaned the filter and we still have fuel issues, truck runs like ass and stalls when you move it around, I assume its sucking water from the bad tank. When holding a steady throttle, it misses/coughs sputters. I guess its new fuel tank/sending unit time...
The title is all messed up, I have to pay for the last owner to move the title over to his name, do a power of attourney and then pay to have the title moved to my name... and a bunch of other BS... going to cost $250 to title the damn thing but it should be legit once done. Working with the auctioneer and hopefully the previous owner will "own up" to this and do what he legally should have done in the first place.
I am working on getting a list of parts together and pulling the side tank, maybe i can rig up an alternative mounting system.
Old July 18th, 2013, 11:09 PM
Tr00b's Avatar
The guy who owned the truck before was an absolute peach. He paid his side of getting the title straightened out and was super super nice about it, might have made a friend! LOL! I'll probably get title/plates taken care of this Saturday.
So far parts I'm looking at replacing:
Gas tank, sending unit, fuel filters, fuel lines, shock absorbers, radius arm bushings on both radius arms, lower steering shaft bearings/bushings (these I have to get at LMC truck, everything else is RockAuto).
It will be about $300 total.
ASwaff400 , bikertrash3531 , Booba5185 , Bubi , Dieselpro , glc , JedCrone , JSoko , KarenP , mrtief , skatebowd , tin man , Tr00b , TwoStroke
New to Me F250 Raleigh 1987-1991 Ford F250 | F350
8 December 31st, 2012 01:04 AM
03 f250 egr swilliam691 1999-2007 Ford F250 | F350
4 May 3rd, 2012 07:49 PM
Mr. F250 pcanonge New Member Introductions 5 November 30th, 2011 08:57 AM
f250 ford 79 New Member Introductions 6 November 15th, 2011 11:08 PM
77 ford f250 fordboy Auto Parts Wanted
1 April 23rd, 2010 11:47 PM
2wd , f250 , toy
