Quantcast auto transmission - Ford Truck Club Forum
Old June 26th, 2012, 04:11 PM
joseywales's Avatar
joseywales joseywales is offline
Images: 5
Default auto transmission
New member, new truck. 75' F-250 high boy, ranger package, 360, pb, ps, ac, 4 sp, no rust, unmolested, 98K. I bought it for some mountain property to plow but I might clean it up more than expected.
My question is, what are these worth cleaned up and I was considering putting an automatic transmission in it. I have the tranny but not a shifter or linkage etc. Opinions on the auto and does anyone have any suggestions on getting the rest of the parts?
Never heard of a high boy until I bought this but it sounds like there is a little following.
Thanks
Old June 26th, 2012, 04:16 PM
Welcome to the forum!
There is a following.
Enough to invest money into it in hopes of making some... don't know about that much of a following! I am not a wealth of info on this trucks, but some other members are. They will chime in soon enough!
Old June 26th, 2012, 04:29 PM
You say it's unmolested? I'd leave it as is if it has 98k on it and is unmolested. I'd need to see pics to tell you what it's in the ballpark worth, plus that 4spd w/ granny 1st and 4x4 with low range will pull damn near anything.
Old June 26th, 2012, 04:44 PM
joseywales's Avatar
Images: 5
New to anything like this. How do I post pics?
Old June 26th, 2012, 04:52 PM
Take some pictures of it, go to the gallery here on FTC, click "Upload", then select photos, then on the drop down bar select "FTC Member's Image Gallery" then click "Upload" this time at the bottom, once uploaded go to the photo, highlight the image code and paste it into you're post on here.
You'll need to click on the link in my signature titled "How to fix your FTC pics" cause at the moment there is a bit of a problem with the gallery modifying the code for the photos, not to hard to erase the mentioned stuff in the thread. Or just post them and I can modify the code and post the big version of the pics.
-Blue.
Old June 26th, 2012, 07:41 PM
joseywales's Avatar
Images: 5
Couldn't get any pics over here. They are in the gallery under classic trucks. Any input on getting parts and what to do, and not do, to it are appreciated. Thanks
Old June 26th, 2012, 07:50 PM
A truck in that condition is worth about 2k-2.5k. No rust on it? You should be able to get most parts at O'Reilly parts stores and other big chain parts stores, there is also www.rockauto.com www.jegs.com www.summitracing.com
Just don't hot rod it and start adding big wheels with spinners on it and you'll be fine:) I would check the wheel bearings in the front axle along with the brake pads and rotors, I usually will replace the bearings in a new to me truck anyway so I know that they are new and have no miles on them and are packed correctly.
Old June 27th, 2012, 12:28 AM
joseywales's Avatar
Images: 5
Thanks Ken.
Old June 27th, 2012, 12:43 AM
No problem:) Be sure and see if that is a 360, I have some links I'll post up in a minute on "Decoding" the door tag for you're truck and how to measure to tell the difference in a 360/390.
Let me go dig up the posts.
Old June 27th, 2012, 12:49 AM
Here is how to to whether you have a 360 or a 390(the easiest way):
Turn the crank by hand with a socket and breaker bar until it's on TDC, take spark plug #1 out, insert dowel rod and put your thumb where it comes up to the top of the spark plug hole, use the marker to mark it. Take dowel rod out and spark plug #4 out, re-insert dowel rod in hole #4 repeat. Measure the distance between the two lines, 360= 3.50 stroke, 390= 3.78 stroke.
And how to Decode you're door tag:
http://www.fordtruckclub.net/forum/s...ead.php?t=5648
78 250 , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , Booger , DoubleDee , joseywales , mjohansen11 , nine5flareside , Russo2 , theFenceGuy
How To Rebuild the Ford FMX Transmission BADSHOE BADSHOE Productions 0 June 10th, 2012 10:43 AM
Disadvantages of Do It Yourself Transmission Repair JSoko Garage Talk: Shop Class 101 0 March 4th, 2012 09:32 PM
How to know when your Auto Transmission needs a fluid change BigBlue79 Garage Talk: Shop Class 101 3 December 19th, 2011 09:57 AM
f150 transmission bobmc 4x4 1992-1996 Ford F150
3 November 14th, 2011 05:54 PM
Auto industry shows a pulse at L.A. Auto Show BigT67 General Discussion
1 December 5th, 2009 12:35 AM
auto , transmission
