Quantcast 4-8-13 small update - Ford Truck Club Forum
Old April 8th, 2013, 03:59 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
Default 4-8-13 small update
heres a quick update on the truck.. it's got nearly 2k miles on the new engine.. and it's now around 7k on the new trans. both are doing amazing.
the Speed Density setup is slightly better than it was originally after the engine was installed.. so it does learn.. if i had 1.6 roller rockers the truck may be ok on speed density. but im keeping the 1.72's.
the rear end is gonna need a rebuild before to long.. it has a small whine at times. fluid is full and good.. checked that at work a few days ago. already knew the limited slip clutches were toast..
removed the decals off the rear window for the performance parts.. tired of haters arguing with me about what i have and what i dont have.. the decals are still on the truck and you'll see below where.. it's a neat not thought of spot. really neat for car shows.
pictures..
Old April 8th, 2013, 09:33 PM
You need clear or smoked like baadd
Old April 8th, 2013, 09:36 PM
Images: 620
Liked 179 Times in 161 Posts
try a $12bottle of friction modifier in the rear end, I use 'Auburn Gear'
Old April 8th, 2013, 09:53 PM
nflfreak43's Avatar
more important things to spend the money on right now.. like a A9P and MAF sensor for the conversion..
BigBlue79 , bikertrash3531 , brick13 , glc , JohnJ , JSoko , nflfreak43 , Russo2 , SlydinClyde , The Frankster
Update on the 63 4X4 woody36206 1948-1983 Ford F100
14 December 27th, 2012 08:11 PM
Update Your Truck - Amp Research Gearz Gearz 0 March 8th, 2012 07:30 PM
Update on the McLaren MP4 development AutomotiveTV AutomotiveTV 0 March 1st, 2010 09:40 AM
UPDATE: Stabbing accused not a bad kid Bates88 General Discussion
2 August 8th, 2009 12:39 PM
small , update
