Quantcast Truck wont start after tps replacement ??? - Ford Truck Club Forum
Old September 12th, 2013, 08:25 AM
yahnke's Avatar
yahnke yahnke is offline
Default Truck wont start after tps replacement ???
Replaced TPS on my f150 302 now truck wont start,pulled coil wire no currant out of the coil. The tps according to direction can be adjusted?? dont know how to adjust and will that keep the coil from firing??? Thanks Steve
Old September 12th, 2013, 11:59 AM
yahnke's Avatar
foot note this is a 1995 f150
Old September 12th, 2013, 03:56 PM
It shouldn't keep if from firing, it could make it run like crap, but it's still fire I believe. Have you check for voltage at the coil? Does the fuel pump prime?
Old September 12th, 2013, 06:46 PM
yahnke's Avatar
Voltage to the coil no output voltage,ran good when we brought it to the shop,now wont start have not checked the pump,belive its the coil but why all of a sudden coil goes bad??
Old September 19th, 2013, 06:01 PM
rikard's Avatar
rikard rikard is offline
Images: 7
With the ignition switch on see if you have 12v on one of the low voltage connector on the coil. If you have 12v on one put a test light or voltmeter on the other low voltage connector and have some one try to start the truck. If the light/voltmeter goes on/off as the engine is turning over you could have a bad coil. If the light does nothing than the problem is else where. Try pulling the computer codes.
Regards
rikard
Nelly Belle 95 F150 XLT SC SB 4x2 300 5 speed 242k miles
(View-All Members who have read this thread : 9
bikertrash3531 , Booba5185 , elwray , glc , JSoko , rikard , Russo2 , The Frankster , yahnke
My Truck wont og in reverse js1990 2004-2008 Ford F150
7 January 15th, 2013 11:05 PM
1992 ford f150 5.0 engine wont start tommie641 1992-1996 Ford F150
12 October 19th, 2012 10:36 AM
once agin my 74 f250 it wont start ktm126 1948-1986 Ford F250 | F350
10 August 1st, 2012 03:30 PM
1974 f250 4x4 wont start ktm126 1948-1986 Ford F250 | F350
15 March 21st, 2012 04:14 PM
1995 F150 Wont Start nine5flareside 1992-1996 Ford F150
14 October 12th, 2009 03:48 PM
replacement , start , tps , truck
