Quantcast Official Engine Additives Thread - Page 4 - Ford Truck Club Forum
  #31
Old April 11th, 2013, 11:53 AM
The Frankster's Avatar
Liked 12 Times in 9 Posts
I believe this will stay on topic. I have a late 80's or early 90's JD RX 75. It smokes at start up but eventually clears up. The old thing mows like crazy but it's getting old. What if any would be a good additive to save it as long as possible? It has a Kawisaki balanced 9hp engine that runs smooth as silk. Oh yes, filled up and by a rough guess, my truck s getting 17 .something mpg in the city. whoo hoo!
  #32
Old April 11th, 2013, 12:09 PM
if its an overhead valve engine, its just oil leaking down the valve stems after you shut it off and then the oil burns off when you start it
I would not worry about it and just keep on cutting
  #33
Old April 11th, 2013, 07:06 PM
okie dokie
  #34
Old April 12th, 2013, 01:52 AM
What weight oil are you using in it?
  #35
Old April 12th, 2013, 06:39 AM
only oil additive ive used in the f250 is Rev-X, #7 injector had a stiction issue on cold mornings, added rev-x, no more sticking injector
  #36
Old April 12th, 2013, 09:02 PM
I believe 10-30 Penzoil.
  #37
Old April 12th, 2013, 09:19 PM
I use stright 30w in all my small engines
aand other engins as well
  #38
Old April 13th, 2013, 01:22 PM
You shouldn't use multigrade in a small engine - they are built for straight 30 small engine oil. The only exception is in real cold weather - snow blowers, etc.
  #39
Old April 15th, 2013, 07:16 PM
I think it may be just 30, I'll have to ck. Haven't been home long.
90f150xltcenturion , ASwaff400 , barriosman , BigBlue79 , bikertrash3531 , bluesky , Booba5185 , catmechanic07 , glc , Herbie , JSoko , nflfreak43 , nine5flareside , Russo2 , skatebowd , The Frankster , Tr00b
Official Junkyard Run Thread Booba5185 Garage Talk: General Tech Talk 68 May 4th, 2013 09:34 AM
The Official Stuck Thread DIXIE FIX Garage Talk: General Tech Talk 49 August 19th, 2010 11:03 AM
additives , discussion , engine , information , official , thread
