Quantcast osu ford - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-100 | F-150 SERIES > 2009-2014 Ford F150
Old January 22nd, 2019, 06:22 PM
osu1970's Avatar
osu1970 osu1970 is offline
Default osu ford
2010 super crew f 150 replaced rear driver lock actuator and lock still does not work any ideas
Old January 22nd, 2019, 06:59 PM
Liked 110 Times in 106 Posts
I assume you mean electrically, with either the master lock button or the local lock button? Can you lock and unlock it manually?
Old January 23rd, 2019, 02:02 PM
osu1970's Avatar
yes I can unlock manually I installed a new lock actuator and still nothing could there be a ground problem or master switch problem
Old January 23rd, 2019, 02:14 PM
You do need to check the wiring going into the door.
harrison28 (January 23rd, 2019)
Old January 26th, 2019, 01:22 PM
osu1970's Avatar
Thanks for your responces so far no luck on replacing lock actuator very low voltage coming to back door lock
Old January 26th, 2019, 01:25 PM
osu1970's Avatar
Any experiences with a blue picture on backup camera 2010 f 150 xlt.I have had one person tell me they took emblem off and bracket unplugged the harness and dialect grease on the contacts and it then worked
Old January 26th, 2019, 03:15 PM
Sounds like a loose connection for your camera. I would try the removal, greasing, and reconnecting the camera.
Old January 26th, 2019, 06:07 PM
Wiring issue.
Old July 26th, 2019, 06:10 AM
HANKU's Avatar
HANKU HANKU is offline
Decent, need to accomplish something like this with mine.
« Recall: 2013 Ford F-150 (again!) | There is no next thread »
(View-All Members who have read this thread : 41
Anthonyjog , Bettybuiny , Billygenna , BrianRed , Danielfuh , DavidFloca , DennisPoili , Donaldjen , DonaldVaf , DonaldWoche , EmersonSwone , Frankcocyxw , FrankCoosy , glc , HANKU , harrison28 , her , Jesseplosy , JSoko , KeithFoult , KelvinPriow , LiamMarry , Michaelbic , osu1970 , Ramonvog , Raymondagozy , Rebeccarap , Richardkig , RobertVog , Rodneyvat , RonaldFon , Ronnietah , sbpbrent , Shanehib , Stephennah , The Bone , ThomasKaG , TimothyNut , tranpan12 , Williamidons , XRumerTest
ford , osu
