Quantcast transmission cooler - Ford Truck Club Forum
Old June 22nd, 2014, 04:13 PM
mjohansen11's Avatar
mjohansen11 mjohansen11 is offline
Images: 2
Default transmission cooler
This has probably been brought before, but, on my '96 F150XLT, I've replaced the rad, and tranny cooler lines, since the old ones broke when removing the old rad. I've used 5/16 brake lines. Problem is when I connected to the tranny cooler, there was a leak. When I tried to tighten the line a touch more, it seems like it stripped and came right out of the cooler.
My questions are, anyone else have this happen? Anyone else use brake lines for tranny lines? And, should there be some more threads protruding out from the large nuts on the tranny cooler where the lines connect?
Any help would be much appreciated.
Thanks
Mike
Old June 29th, 2014, 08:03 AM
Images: 2
Update, I replaced the tranny cooler, found one at the wreckers for $20. Made a new line and everything works perfect! The 5/16" steel lines work great and for the rubber flex lines I've used some 5/16" I.D. braided line that I got from work. Fits like a glove.
Old August 13th, 2014, 10:40 AM
leojr's Avatar
leojr leojr is offline
How did you make the new lines, does this require a flaring tool? I may need to do something similar on mine.
Thanks!
96 F250 4x4 PSD auto CCSB
D60 axle swap with F350 front springs
SD (B code) rear springs and 4" factory F350 blocks
Explorer grab handles
Remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread
Link to my OBS air vent R&R thread
Old August 13th, 2014, 10:50 AM
a flare is preferred
but most folks don't ream the inside of the tube after cutting and it makes for a bad / leaking connection
plus if doing this in place the flare tool can be a PITA
I have had good results using compression fittings on the trans lines
easy to install and user friendly; I like to put a dab of pipe dope on the ferrel
if needed for a repair you can substitute soft copper tube
it's just hard to find 5/16" OD copper
for which I use a reducing coupling and increase the size of the copper
I only use copper for a repair and only short lengths
now on a brake line - flare only
1994-f150-bud , ASwaff400 , Booba5185 , dkenny9 , glc , JSoko , leojr , Matthew , mjohansen11 , Ozzie , Russo2 , The Frankster
Flex-a-Lite GM Aluminum Radiator and Electric Fan, Transmission Cooler MOTORZ TV MOTORZ TV 0 December 13th, 2013 12:52 PM
55 223 six od Transmission John Lightcap 1948-1983 Ford F100
2 October 14th, 2012 10:23 AM
power steering cooler Ol Red 1999-2007 Ford F250 | F350
15 September 20th, 2012 01:04 PM
transmission little dave 1973-1991 Ford F150
10 July 31st, 2012 08:14 PM
auto transmission joseywales 1948-1986 Ford F250 | F350
9 June 27th, 2012 12:49 AM
cooler , transmission
