Quantcast Finishing Engine swap 1991 F150 5.8 - Ford Truck Club Forum
Old September 11th, 2014, 05:53 PM
barrett_s's Avatar
barrett_s barrett_s is offline
Default Finishing Engine swap 1991 F150 5.8
Have a few questions on my 1991 F150. Swapping the 5.8 from a bronco.
Ground straps? There's a really large braided copper line from the neg battery post, and it used to go under the engine somewhere. Thought it was a negative for the starter, but 8" short, think it's a main link to the frame?
Upper small diameter hose from the radiator fill neck. It crosses the top of the radiator, then changes to rubber and heads toward the passenger side of the engine, but don't know where it was feeding. No inlets left at this point, see pics.
Almost ready to restart, it's been a yearlong project! Wish me luck!! First time engine swap.
Shawn B
Spokane, WA
Old September 12th, 2014, 06:32 AM
ground wire and preasure release over flow usually goes into your plastic reservoir tank i think
Old September 21st, 2014, 01:14 AM
barrett_s's Avatar
But the collection tank is on the far side of the engine bay, This hose goes to the opposite side, and seems like it might have been top/bottom of the throttle body? still no good answers.
Also having trouble starting. Was getting clicking, but now it seems like the ignition switch is all sloppy in the cylinder. like it's flopping around, and not engaging the switch. Replaced all the main heavy wires, checked for low resistance on all of them.
Old September 21st, 2014, 06:48 AM
that hose sould have been connected to the top side of the throttle body. on both my 302 and 351 the inlet came from around the t-stat/waterpump area, then T'd into one of the heater core hoses. both motors are from '95 model year trucks... i ended up bypassing the system as the metal pipe on the TB rusted through... that hose hooked to your TB looks somewhat new and not OE. if everything is hooked to the TB and doesnt leak, you can remove that rubber and metal pipe and plug it off at the radiator.
Old October 5th, 2014, 11:12 PM
barrett_s's Avatar
Thanks, All. I had figured that, ASwaff, thanks for the confirmation.
Just one last question. I have been moving toward start, and have all the electrical connections put back. I have tested the starter on the bench, and replaced the battery for new. 12.5 V at rest. 675 CCA. The key was floppy, seemed like it was spinning in the ignition switch. Replaced ignition switch. No life as I turn the key. Also, no dash lights, and the door bonger sounds like its getting 5 v, sounds like a million miles away. Headlights and dome lights okay. Just went through all the fuses under the driver side cover. Are there more fuses? Any idea why the key is just turning without springing back? How I get to starting?
What might be going on? I'll be happy just for guesses, at this point.
Old October 8th, 2014, 06:58 AM
12.5 V for a new battery is low
sounds like a bad ground on the dash lights and bonger
ASwaff400 , barrett_s , FXRS , glc , harrison28 , IrishKRO , JSoko , rtdidaho , Russo2 , skatebowd , stro
My Restored 1991 Ford F150 NITE NiteVizun More Special Edition F150's
6 November 5th, 2018 11:57 PM
1991 F150 4X4 Hub/Rotor Availability? RetTech 1973-1991 Ford F150
13 December 21st, 2012 05:40 PM
1991 f150 5.0 efi DON CHILDS 1973-1991 Ford F150
12 October 10th, 2012 03:44 PM
Finishing Touches For Rebuilt Engine - LMC Truck Gearz Gearz 0 April 17th, 2012 10:11 AM
1991 , 351w , battery , engine , f150 , finishing , ground , hose , plumb , radiator , swap , water , wires
