Quantcast 351W Swap - Page 2 - Ford Truck Club Forum
Old September 4th, 2015, 07:08 PM
Sounds like good progress. Can't wait to see how it turns out. Post some pics of your build process if you get a chance.
Old September 6th, 2015, 07:20 AM
thanks for the up-date
Old January 14th, 2016, 09:19 PM
IrishKRO's Avatar
IrishKRO IrishKRO is offline
Images: 5
Another update! So I downloaded a 10day free trial of Engine Analyzer Pro v. 3.9. I plugged all my specs in. Thankfully I've been researching for like 2 years so most of it I have memorized. I plugged in about 20 different cam setups and ran them all through the simulator. I had a custom grind quote that was:
GRIND FW266/272H113+5
DUR @ 211/217
LIFT .471/.485
LSA 113
INT C/L 108
PRICE 205.00 + FRT
The other cam I was considering was comp cams 35-239-3. The custom grind had about 15 more ft/lbs over the CC on euntil about 4500 RPM then the higher duration and lift of the CC grind won out.
For shits and giggles(language?) I threw in the specs for Crower's Baja Beast grind. To my surprise, it blew away every other cam I had sim'd.
The simulator had me at 300ft/lbs starting at 1k RPM, peaked at 362ft/lbs at 3500 and fell off hard at 4800 RPM. Considering that it's a daily driver, this torque curve is phenomenal.
Old January 14th, 2016, 09:22 PM
IrishKRO's Avatar
Images: 5
As far as progress is concerned, my parents are paying my wife and I(mostly myself) to tile their house so I should have all the funds to purchase what I still need by mid february. I'll be sure to post pics of the engine. Also, another thing that I am doing is using a 5.0 plenum on the 5.8. The port shape and size for the 5.0 is WAY better than the 5.8. I'll be sure to post picks of the port job I do.
Old January 15th, 2016, 11:07 AM
I think it may just be for a carb manifold
but the 5.0 won't fit a 5.8 cause the 5.8 has a higher deck height
Old January 16th, 2016, 01:48 AM
IrishKRO's Avatar
Images: 5
Correct you are good sir! But we aren't talking about the intake manifold, we're talking about the plenum.
  #17
Old January 16th, 2016, 09:28 AM
yep, I kinda figured that
when engines when to electronic ignition and injection; I did not stay current
as all we had were carbs points & condensor
now days on the new engines if I have a problem somebody with the know how takes care of me; I'm limited to the things that bolt on, brakes, suspension axles and such
  #18
Old February 16th, 2016, 12:09 AM
IrishKRO's Avatar
Images: 5
Alright guys, first batch of parts is in. I got pretty much everything to complete the short block; Pistons, rings, main bearings, rod bearings, main studs, oil pump, arp con rod bolts, arp engine fastener kit plus some exhaust tubing to change my exhaust so it comes out over the rear axle.
  #19
Old February 16th, 2016, 09:01 AM
great
post some photos
  #20
Old October 24th, 2017, 01:21 PM
Wonder how this all turned out?
3rd-coast-thumper , 91klunkr , ASwaff400 , Atate5 , Booba5185 , Cass , Charlessam , FXRS , glc , gwfan , harrison28 , IrishKRO , JSoko , ncranchero , RichB , RKTDR , Russo2 , Thesmanman , unclebeer
351w Heads BigBlue79 Garage Talk: Engine & Drivetrain 11 February 17th, 2015 08:54 AM
351W Build IrishKRO Garage Talk: Engine & Drivetrain 28 April 16th, 2014 08:27 PM
351w vs 351c 4v/2v RoadHawg 1992-1996 Ford F150
14 November 23rd, 2013 09:23 AM
84-87 351W H.O. Information nflfreak43 1973-1991 Ford F150
3 March 5th, 2013 12:07 AM
351w , swap
