Quantcast 1989 F150 XLT Lariat 2wd Dash shift pattern and Transmission gears - Ford Truck Club Forum
Old June 9th, 2015, 01:39 PM
RKTDR's Avatar
RKTDR RKTDR is offline
Question 1989 F150 XLT Lariat 2wd Dash shift pattern and Transmission gears
I recently bought this truck, and it has been awhile since I have done any automotive mechanicing. A lot of things have changed and I need to get up to speed. According to all information I have, my truck has the E4OD transmission. In the owners guide there are two displays in the dash panel (1) PRN(D)D1
(2) PRND21
The (2) is what is shown in the dash. I have been asked if there is a button on the end of the shift lever. There is not.
Please correct me if I am wrong,because I surely do not know for sure.
My assumption is that the E4OD will automatically shift into and out of overdrive as the engine pull and RPM warrants. Which negates any need for a button on the end of the shifting lever. The (1) display I assume, is for the AOD transmission.
Old June 9th, 2015, 10:13 PM
IrishKRO's Avatar
IrishKRO IrishKRO is offline
Images: 5
The E4OD is electronically controlled. If you do not have the button then I would assume that the only control you have over it going in and out of overdrive is whether the selector is on D or 2. But what it sounds like is that you have a C6 tranny. Do you have overdrive? You can also check by counting the bolts on the trannys pan.
C6 - 17 bolts
AOD - 14 bolts
E4OD - 20 bolts
Also, what size tires does it have an what rpm are you at while at 55mph?
F100Chief , FXRS , glc , gwfan , harrison28 , IrishKRO , JSoko , ncranchero , RKTDR
my 1989 ford f150 still.learning New Member Introductions 5 January 1st, 2013 04:28 AM
Converting An Automatic Transmission To A Standard Shift Gearz Gearz 1 September 18th, 2012 10:10 PM
FS: 2009 Ford F150 Lariat 4x4 SFssft1911 Vehicles For Sale
4 November 6th, 2011 04:47 PM
'09 Ford F150 Lariat SuperCrew 4x4 Lifted SFssft1911 Vehicles For Sale
7 October 27th, 2011 02:28 PM
How to Change the EGR Valve on a 1989 F150 With 5.0 JSoko Garage Talk: Shop Class 101 1 October 14th, 2011 10:28 AM
1989 , 2wd , dash , f150 , gears , lariat , pattern , shift , transmission , xlt
