Quantcast 2017 Ford Super Duty Recalled, Gas Tank Might Fall Out - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-250 | F-350 SERIES | SUPER DUTY > 2017-2020 Ford F250 | F350
Old January 5th, 2017, 08:36 PM
Exclamation 2017 Ford Super Duty Recalled, Gas Tank Might Fall Out
2017 Ford Super Duty Recalled because the Gas Tank Might Fall Out
Ford Motor Company has issued a recall for roughly 8,000 examples of the new 2017 F250 and F350 Super Duty pickups over a concern that a problem with the gas tank straps could allow the tank to fall and contact the ground – increasing the likelihood of a fire, although there have been no reports incidents by private owners.
The 2017 Ford F250 and F350 pickups introduce a new generation of their bestselling Super Duty lineup, with the most significant feature being the lightweight, aluminum body. The newest Super Duty pickups are the most capable in the heavy duty consumer market, so it comes as no surprise that the company has already sold more than 8,000 examples of the new 2017 F250 and F350 before the end of 2016. Unfortunately, 8,000+ new Super Duty pickups are being recalled for a concern that the gas tank straps could fail and allow the tank to fall to the ground.
The 2017 Super Duty Gas Tank Strap Recall
According to Ford Motor Company, the cause for this recall is that the gas tank straps of the 2017 Ford F250 and F350 Super Duty pickups could have been installed without a reinforcement bracket on the front fuel tank strap. Without this reinforcement bracket, the gas tank strap could separate from the frame.
As you might imagine, if your gas tank straps fail, your gas tank can fall to the ground, but it won’t fall completely out, as the filler hose and fuel lines will keep the gas tank connected to the vehicle. However, should the straps fail while one of these trucks is being driven, dragging the tank against the ground at speed could cause the tank to fail. If the gas tank fails while moving, it would only take one spark to start a heck of a fire.
The good news is that Ford Motor Company has received no reports of any issues stemming from the gas tank straps failing in a 2017 F250 or F350, so it seems as though the automaker has caught this problem before any owners have experienced the issue first-hand.
The recall explains that “certain” 2017 Ford F250 and F350 Super Duty pickups are included and all of those trucks were built at the Kentucky Truck Plant between August 10th, 2016 and September 17th, 2016.
The fix seems fairly simple, as the dealership technician will inspect the gas tank straps of the new Super Duty pickup to make sure that they have the front reinforcement bracket and if one is not present – the dealership install a strap reinforcement which will prevent the straps from separating from the frame. This work will be performed free of charge and the work shouldn’t be all that time intensive, but I still always recommend that people drop their vehicles off and leave them there for the day to be fixed, regardless of the work being done.
Any recall is bad news for an automaker, but Ford caught this issue before any problems came of it and most importantly – this problem has nothing to do with the aluminum body.
If you own a 2017 Ford Super Duty pickup which you believe was built during the aforementioned time period, contact your local Ford dealership with your VIN handy to see if your truck is included in this recall. The reference number is 16S45.
« There is no previous thread | 2017 F350 Light bar accessories »
Eng89ine , glc , harrison28 , JSoko , Kammmmak , rAzkid , Red#6
2017 Ford F-Series Super Duty JSoko 2017-2020 Ford F250 | F350
4 October 9th, 2017 08:25 AM
97 Ford F-250 super duty 5.8 v8 Bigcodyb 1992-1997 Ford F250 | F350
0 February 1st, 2016 12:07 PM
FORD SUPER DUTY DOES HEAVY LIFTING: GRABS 50 PERCENT OF HEAVY-DUTY MARKET, ACCOUNTS FOR SEGMENT GROWTH Bates88 Garage Talk: General Tech Talk 1 November 15th, 2010 03:27 PM
Ford and Toby Keith are giving away a 2011 Ford Super Duty Bates88 Garage Talk: General Tech Talk 0 June 30th, 2010 05:05 PM
1961 Ford F-950 Super Duty marmaduke Ford's Not Listed 5 March 2nd, 2010 10:15 PM
2017 , duty , fall , ford , gas , recalled , super , tank
