Quantcast Timing recommendation - Ford Truck Club Forum
Old June 5th, 2017, 03:34 PM
Hornet's Avatar
Hornet Hornet is offline
Default Timing recommendation
Hi guys, just joined up. Thanks for having me.
I have a 1973 F100, 302 with Windsor JR heads, E303 cam and a Edlelbrock 1406.
The truck had no spark and had not run in a bout a year. I replaced a Chinese knock HEI style distributor with a PerTronix Distributor 134600.
The truck now starts great and runs well but I'm not clear where the timing should be. I've tried 10, 12, 14 degree. The engine is running rich per the plugs and smell test. I've adjusted the carb but cant see to lean it out.
Am I missing something with the timing on the E303 cam, should I be at a higher setting than say 14?
The Road Goes On Forever
Old June 5th, 2017, 04:17 PM
Hornet's Avatar
Well here's my first rookie mistake , looks like I put this in the wrong forum.
Can one of the mods please move this to the garage forums.
Old June 6th, 2017, 12:19 AM
This forum is fine.
Advance the timing till you get spark knock, then retard it 2 degrees.
You can only adjust the idle mixture. To lean it out across the whole range you have to change the main jets.
Old June 6th, 2017, 07:54 AM
Hornet's Avatar
Thanks for the reply GLC, I'll give it a go over the next week or two to see how she runs.
Dusto1002 , glc , harrison28 , Hornet , JSoko , larrhy2 , safeullli , SemperFit
romeo 4.6 timing chain issue wip 1997-2003 Ford F150
1 September 11th, 2015 01:44 PM
1997 f150 timing chain question wip New Member Introductions 4 September 9th, 2015 08:58 PM
Timing chain issue skatebowd 1997-2003 Ford F150
32 April 13th, 2012 11:10 AM
How To Replace the Timing Chain on a '97 4.6L JSoko Garage Talk: Shop Class 101 6 January 13th, 2012 08:58 AM
Timing Belts and Wiring Diagrams HawaiianF150 Garage Talk: Shop Class 101 0 September 6th, 2010 01:58 PM
recommendation , timing
