Quantcast Leak next to the EGR , Help Please ! - Ford Truck Club Forum
Old June 20th, 2017, 01:23 PM
Southern Swamp Boy's Avatar
Southern Swamp Boy Southern Swamp Boy is offline
Default Leak next to the EGR , Help Please !
I recently Purchased a 1995 Ford F-150 XLT 5.0L V8 4x4 and have been discovering little things here and there that I've been fixing as a project/daily driver. I've recently began experiencing some jumpy transmission and slipping problems and upon inspection of the engine noticed there was a leak next to the EGR but I don't know what the specific piece is called nor if its the cause of the Transmission problem. As well as what would be the cause and the repair for it The spot looks like a side ways double barrel or pair or Binoculars. Its just right of the EGR on the left side of the engine and is leaking as i drive but i can't determine what is leaking due to the Fact that the previous owner did not take care of this truck and the systems inside have a lot of lack of care. Thank you for your time and any answers or tips you may offer.
I have Photos and a Video to post as well.
Video Link here :
https://www.youtube.com/watch?v=mrEfPU8HsM4
Last edited by Southern Swamp Boy; June 20th, 2017 at 02:09 PM. Reason: Attaching a Video
Old June 21st, 2017, 09:57 PM
Those are freeze plugs. You have a coolant line that goes into the top of the throttle body and the return comes out of the bottom. There is also a quarter sized freeze plug behind the throttle body also. That looks like nasty coolant all over the place blown around by the fan as its leaking.
Name:	Side of TB.JPG
ID:	1355   Click image for larger version
Name:	Back of TB.jpg
Bulldog74 , glc , harrison28 , Herbie , jheat , Kmh3212 , Southern Swamp Boy , The Frankster
Transmission leak H Martin New Member Introductions 3 December 19th, 2016 01:20 PM
Transmission leak jsilva1987 1992-1996 Ford F150
1 April 19th, 2016 12:15 AM
Vac,pump oil leak Dave8N in Pa 1992-1997 Ford F250 | F350
1 August 16th, 2014 03:23 PM
Firewall coolant leak? JCruz 1973-1991 Ford F150
12 September 3rd, 2013 07:44 AM
colant leak michaelsnodgrass18 1992-1996 Ford F150
22 January 21st, 2013 08:10 PM
1995 , 4x4 , 5.0 , egr , engine , f-150 , leak , transmission , xlt
