Quantcast 1997 351W EFI... - Ford Truck Club Forum
Old October 5th, 2017, 11:29 AM
Thesmanman's Avatar
Thesmanman Thesmanman is offline
Default 1997 351W EFI...
I'm a newbie here. Thanks for having me.
I'm sure this has been asked, but I would like to get some input on this. Before anyone says why go carb?,..My son just wants to.
My son has a 1997 F350 with a 302 (motor is tired) in it now that is EFI with a C6 Trans. We have a 97 351W EFI. He wants to convert the 351W over to carburetor. He said 650DP or 750DP? I told him a 650 would be fine? What are the suggested parts for a mild build that won't break the bank? The engine runs well. Decent intake, long tube headers, a mild cam (using stock valve train what would be a decent cam to use) with new lifters and springs if needed, timing chain and gear set and gasket set/seals. I've read that the distributor needs to be replaced? Can a standard HEI be used and how is it wired? Also what about the wiring,.. does it need to be wired differently and what do we need to do with the PCM? Can we use the electric fuel pump that's in the tank by adding a regulator? Is there anything else we need to do with the fuel system? Anything that I'm missing that needs to be done to convert it over? Anyone have any info on this or links to a conversion like this or have done this themselves that has a build thread on this? Also, does anyone have the torque specs on the engine and main and rod bearing acceptable clearances? Sorry for all the questions, but we need some help with this.
Thank you,
John
69mock1 , Booba5185 , frank5079 , FrankCoosy , glc , gt350 , harrison28 , JSoko , KeithFoult , Thesmanman
351W Swap IrishKRO 1973-1991 Ford F150
19 October 24th, 2017 01:21 PM
351w RichB 1973-1991 Ford F150
1 May 11th, 2017 10:01 PM
help with a GM hei on 351w tmace 1980-1986 Ford Bronco
5 January 2nd, 2016 12:46 AM
351w Heads BigBlue79 Garage Talk: Engine & Drivetrain 11 February 17th, 2015 08:54 AM
351W Build IrishKRO Garage Talk: Engine & Drivetrain 28 April 16th, 2014 08:27 PM
1997 , 351w , efi
