Quantcast Transmission fluid temperature monitoring - Ford Truck Club Forum
Old January 19th, 2019, 03:30 PM
bigmac's Avatar
bigmac bigmac is offline
Default Transmission fluid temperature monitoring
2011 F250 6.2l gas.
I am aware of the factory transmission temperature gauge basically being a "Dummy Gauge" only moving when your already in the 220 range. Obviously I would like to accurately monitor the temperature when towing heavy.
I have read that the sensor itself is precise to the point of 1/10th of a degree, but the gauge itself is basically worthless.
I would like to avoid installing a bung in the pan for another sensor, Id rather use the factory sensor to take the reading. That being said I'd like to purchase an obd2 monitoring system. I've installed gauges and senders in other vehicles and I really don't care to go through the trouble when I could just plug something into the obd2 reader instead.
One common thing I keep seeing is that folks buy an obd2 gauge and everything works fine EXCEPT for the transmission fluid temperature...
has anyone here had any luck with a simple obd2 gauge that works for TFT?
Thanks all.
Old January 19th, 2019, 04:00 PM
Liked 115 Times in 111 Posts
It looks like a Scangauge 2 will work.
https://www.scangauge.com/products/scangauge-ii/
Your truck uses the CANSF protocol and there is a X-Gauge for transmission fluid temperature.
https://www.scangauge.com/xgauge/for...d-temperature/
bigmac (January 20th, 2019)
Old January 19th, 2019, 08:13 PM
The Bone's Avatar
The Bone The Bone is offline
Liked 3 Times in 3 Posts
You know there is a temp gauge in the info center. it tells you oil and transmission.
Old January 20th, 2019, 02:08 PM
bigmac's Avatar
I've scrolled through the menu (in the gauge cluster) several times and haven't seen it. Is there some way to change the displays? I have an XLT, I know some models came with a touch screen full display where the stereo is, but mine is just the regular stereo system.
Old January 21st, 2019, 02:36 PM
The Bone's Avatar
Go to gauge mode. Its on the center above the steering column. To use the buttons on the steering wheel and scroll through the menu.
Old January 22nd, 2019, 09:35 PM
bigmac's Avatar
ill give it a shot tomorrow, thanks.
Old January 24th, 2019, 11:00 AM
The Bone's Avatar
It's the top line in the info screen.
harrison28 (January 24th, 2019)
Old January 26th, 2019, 01:44 PM
bigmac's Avatar
from what I can tell there are two style of gauge cluster. One that you are referring to has an LCD display, mine is slightly smaller and has the granularity of your average digital alarm clock. has far fewer features as well.
some folks have swapped the two styles but it seems to require some programming changes to make it work. probably more time and money than I'm willing to put in.
Old January 27th, 2019, 07:55 PM
The Bone's Avatar
You have a XL truck?
bigmac , FirstFord , glc , harrison28 , JSoko , The Bone
Exhaust Gas temperature monitoring Truckvirgin 2011-2016 Ford F250 | F350
2 August 11th, 2016 01:51 PM
Exhaust gas temperature monitoring Truckvirgin Garage Talk: Engine & Drivetrain 3 September 9th, 2015 06:51 AM
How to know when your Auto Transmission needs a fluid change BigBlue79 Garage Talk: Shop Class 101 3 December 19th, 2011 09:57 AM
Quick Tips - Filling Transmission Fluid Gearz Gearz 1 May 31st, 2011 02:36 AM
Time to change the transmission fluid Bates88 Garage Talk: Paint & Detailing 5 May 24th, 2011 06:50 AM
fluid , monitoring , temperature , transmission
