Quantcast Strange HID problem - Ford Truck Club Forum
Old February 14th, 2010, 12:54 PM
2004FX4F150's Avatar
Images: 75
Default Strange HID problem
So I've had my HID fogs for almost 2 years and just last night, had a strange problem starting.
Matt (redhot150) had the same problem immediately, and I think it's weird that mine started so late.
I pulled into parking spot last night, and shut the truck off and noticed my fog lights were still on. Puzzled, I went back to the truck, checked the switch and of course it was off. Shut the door and again they were on. I started and shut off the truck, turned the switch on and off, but they would go out and come right back on.
Let me say this again, truck was off, light switch was off, key was out of the ignition and the lights would remain on. Finally I gave up and removed the fuses for the relays.
Any suggestions on why this would happen? I noticed the where the ballasts were, that there was some snow and wetness, but these have gotten wet before and they still performed fine. Also, this was almost 2 years later, and Matt's started as soon as he installed them.
Don't want to go back to halogens, but looks like this is the only solution.
Old February 14th, 2010, 01:20 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
Had a faulty relay when i installed my light force driving lights and the lights would turn off when activated the relay and on when i de-activated the relay. Plugged in a new relay and it worked fine. Maybe you have something along that line happening
Monthly Recognition Moderator
Check out my videos HERE
Old February 14th, 2010, 01:22 PM
had the same problem when i had fogs on my truck, any time after 4wheeling the lights would stay on. the inside of the relays got wet "jumping" the circuit. just unplugged the relay and let it dry out. ended up replacing it a few weeks later, then a week after that my lights and lower valence got torn off somewhere on a trail in colorado
Old February 14th, 2010, 02:11 PM
Old Blue's Avatar
Images: 384
Well thats a easy way to solve that problem
Old February 14th, 2010, 02:17 PM
I've seen this a few times with my truck with halogens.
the smaller relays (6 grey ones), one of those was doing exactly what you described intermittently. It was turning my fogs on, when the keys were off and the light switch was not touched for 2 days.
Old February 14th, 2010, 05:07 PM
yeah there till up there... somewhere...
Old February 14th, 2010, 08:49 PM
HID = Headache In Disguise
Just made that up! Sorry to read that Vin. Maybe its time to start thinking
about a chevy (he he he). You can hang out with Cat and drink some cold
beers while you make fun of Fords (and how much better they are)!
Or you could be a man and just kick in the lights until they shatter.
Old February 15th, 2010, 10:21 AM
Images: 75
OK webby, think I will try everyone elses ideas first, hope you understand.
Gonna unplug them, let em dry out, if not, replace the relays, if not still, scrap em and go back to standard bulbs.
Thanks everyone.
Old February 15th, 2010, 10:28 AM
Thanks everyone.
Fine, if you dont want to go with a pro who knows, learn the hard way.
Old February 15th, 2010, 10:33 AM
Images: 75
HAHA, I'll take my chances.....
HawaiianF150 , Russo2
tailgate problem tam85 2011-2016 Ford F250 | F350
8 November 6th, 2013 09:03 AM
3 July 21st, 2013 10:10 PM
Trailer wiring problem BigT67 Garage Talk: Towing & Hauling 35 January 31st, 2011 04:21 PM
Strange find on Titan sparks chatter about life BigT67 General Discussion
0 June 8th, 2010 11:40 AM
Man Uses Strange Ploy In Kidnap Attempt BigT67 General Discussion
2 August 28th, 2009 10:52 PM
hid , problem , strange
