Quantcast drive shaft center support (carrier Bearing) - Page 2 - Ford Truck Club Forum
Old March 26th, 2010, 09:14 AM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
Next time.........Air chisel and a torch. Heat the sleeve and chisel like hell! Done it 100's of times. I dont care for the cutting tool method because (1)..its hard to get in the area you want for an even cut, and (2) you never know exactly how deep your cutting and you dont want to damage the flange for the new one to go on.
Ive never had vibration after installing a new one unless it wasnt on correctly. Maybe it isnt on all the way or its jammed on wrong. Did you mark your drivline so the splines line back up in the exact same slots? One tooth off with cause BAD vibration
Black Sheep of FTC
Old March 26th, 2010, 06:06 PM
clockjanitor's Avatar
clockjanitor clockjanitor is offline
definately chisel after heating
Old March 26th, 2010, 10:59 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
the rear u-joint ended up also being bad. by hand if felt good and tight but as soon as they put a screw driver and a breaker bar to it it showed it was toast......
Adrien , x1488x
Custom Carrier Klitch Garage Talk: Brakes & Suspension 7 April 7th, 2010 12:56 PM
Setting pinion bearing preload on the Ford 8.8" axle BADSHOE BADSHOE Productions 0 March 14th, 2010 06:07 PM
Snapped my Drive Shaft OGTerror General Discussion
18 January 19th, 2010 08:04 PM
Aluminum Drive Shaft & Short Shifter Installation MOTORZ TV MOTORZ TV 0 August 25th, 2009 08:47 PM
Childless man released from child support debt Bates88 General Discussion
5 August 11th, 2009 10:36 PM
bearing , carrier , center , drive , shaft , support
