Quantcast home made roof rack - Ford Truck Club Forum
Old August 30th, 2010, 05:47 PM
Default home made roof rack
got a bunch of 3/16 2x2 angle iron from my work, decided to make a roof rack. havent gotten much done on it, just one of the sections cut and welded...
i cut 2 sections at 6 ft and was left with 4 ft left over. cargo space will be 6ft x 4ft. the second sction of the frame i cut at 7'6" which will extend over the cab for offroad lights across the front and flood lights on the sides
heres the idea
cut at 6 ft
tack welded and squared up
section one done
more info and pics to come
Old August 30th, 2010, 07:32 PM
Great idea, powder coating or just going to paint it?
BATES
Banks & PHP Powered
Old August 30th, 2010, 08:09 PM
when i get it finished im gonna call some local powdercoat shops to see how much it will cost for prep+ coating... ill probably end up painting it...
Old August 30th, 2010, 09:39 PM
so far heres the idea that i have...
Old August 31st, 2010, 08:25 AM
Exclamation Holy Weight Limit
keep in mind the weight limit of your fiberglass cap you don't want your flag to fall, everything is held to your Truck by 4 C-clamps and a top heavy load may cause problems on corners or when bouncing around on that dirt road. Look to the inside top, see the square outline of something thick, thats a piece of ply-wood sandwitched in the fiberglass, now look to the edges where the top curves down, even though the curve does give structural support this is thin all the way down to the rails and not made to support a heavy load.
Sorry for all the negative vibes, but I dont want anything happening that would cause you to loose your load and put that old lady down the street at risk, as she or her children will be looking for ; ask 2 of your Honeys to get up there and watch the inside flex.
Then if you decide to go forward; take it apart and cut the ends on a 45degree angle and re-weld for a flush fit, or notch out the bottom of 2 of the angle irons so they all lay flat on the concrete.
I know the frame will not be lite and according to your sketch it will weigh aprox. 155 lbs.for both top and bottom rails, 2x2x3/16; then add the weight of the other stuff you put up there and it could spell disaster
Old August 31st, 2010, 10:02 AM
if need be, i know a very good fiberglass guy that can add more structural reinforcements for dirt cheap, any glass work i need done for that matter...
couple years back my friends and i would hang out at the local walmart parking lot(at 2am), 2 sometimes 3 friends would sit on the topper and the only place it flexed was directly in the middle but was rigid around the outside corners... that was on a daily basis...
Old August 31st, 2010, 02:23 PM
A lot of fibreglass caps (canopies) have a 150lb weight limit on their roof racks.
I like the look of the concept you're doing ASWAFF.
BATES
Banks & PHP Powered
Old August 31st, 2010, 05:34 PM
just got done welding the lower part of the frame, one end is inverted for the lights to mount to...
tack welded
still gotta cut/weld a cross-member 1-1/2 ft back from the front
Old August 31st, 2010, 07:30 PM
Sounds like a NKOTB song, Step by Step!!!
BATES
Banks & PHP Powered
Old August 31st, 2010, 08:12 PM
Sad to say but I don't think ASwaff knows who NKOTB are. Pretty lame but we are getting old! Now lets stay on topic!
BigTrouble , D&J2007F150 , DoubleDee , F150GT , imhsar , nine5flareside , okgearhead , woodrock , zmr2010
Made in Canada Scotts Black FX4 FTC Eastern Canada
50 May 13th, 2012 12:50 PM
home made rod racks ASwaff400 General Discussion
5 August 11th, 2010 01:03 PM
I made it! lil_bizzy New Member Introductions 18 February 16th, 2010 05:05 PM
Build A Tailgating Party Rack on Truck U TRUCK U TRUCK U 0 February 1st, 2010 12:12 AM
home , made , rack , roof
