Quantcast anyone with experience with wheel spacers? - Ford Truck Club Forum
Old November 9th, 2010, 11:09 AM
tylerbotts's Avatar
tylerbotts tylerbotts is offline
Location: outskirts of new orleans in a city called metairie
Images: 8
Default anyone with experience with wheel spacers?
where can i get them and how much are they. i can't find them anywhere!
My dad said he would get hem for me for doing a job i did for him :)
Old November 9th, 2010, 11:44 AM
Quick question, why do you want wheel spacers?
I don't know how you go about getting your truck inspected, but trucks have been known to fail because of wheel spacers. Just a heads up, you may want to look into your local state inspection laws (if you get state inspected that is).
Also, wheel spacers tend to create more load on your tie rods and that can lead to alignment issues. Basically, it will weaken the whole structure and when that happens, things can break... wheel studs etc. or even worse, a tire falling off. Just something to think about.
At the same time, I am sure that there are people out there that swear by them. Personally, it's not for me.
Few links:
http://www.allsprings.com/catalog/fo...el-spacers.htm
http://www.streetbeatcustoms.com/For...Wheel-Spacers/
http://www.wheeladapter.com/ford_wheel_spacers.php
I am not supporting any of these sites as good places to buy from(not that they aren't good places to buy from - I don't know), I just found these links on the internet. Buyer beware!
Old November 9th, 2010, 11:54 AM
tylerbotts's Avatar
Images: 8
it's for my camp truck. it has a 6 inch suspension lift and it's my old truck its an '04 f150 heritage. I been wanting to put wheel spacers on
Old November 9th, 2010, 12:16 PM
herbz's Avatar
herbz herbz is offline
Images: 13
Liked 3 Times in 3 Posts
Everything thing I've ever read on any forum about wheel spacers is they are bad news. I've never seen someone post about them and get a positive response. I think it all comes down to a safety issue because of all the stress put on the parts nine5 mentioned.
________
Volcano Classic
Old November 9th, 2010, 12:55 PM
We've done a lot of custom billet wheel spacers. Generally for guys with duallies that are going for bigger rubber or guys with lifts that want bigger rubber but are staying with stock rims that don't have any offset. Usually the minimum we have done is 2" billet spacers (there are thinner ones, some off-shore steel ones) that are made by a company here in the Lower Mainland of BC.
http://www.wheelspacers.ca/
Have had a lot of success with the spacers to date. Just like a lift kit the spacers can add extra wear and tear on your suspension components though. That is the downside of lifting your truck.
BATES
Banks & PHP Powered
Old November 10th, 2010, 10:37 AM
stay away from WHEEL SPACERS
Old August 4th, 2012, 10:16 AM
Flatbedmark's Avatar
Flatbedmark Flatbedmark is offline
Images: 20
I have used billet steel spacers from these guys for over 10 years, without an issue front and back with my std ball trailer and bobcat and the fifth wheel with two drag cars on a reg bassis.
http://www.southwestwheel.com/fordconversion.htm
Recently had them off and they show as good as the day I put them on, I even magged them for kicks....no cracks.
I tq the inner acorn nuts 105 the outter flats to 140 pounds.
The colorado DOT is very strick, I pass through one, one time a week and they know its a conversion due to my gvw and all is good.
Who knows....But I will ask this, just as my nitrous stroker motors, people say it will knock the sides of the block out but yet no one who posts such things can support it with there own real world use or pics of there cracked blocks, so I ask the same thing of people who do not like spacers, have you used them yourself and if so under what conditions, what brand and pics that support the theory of what went wrong? If wheel spacers were the rolling death some make them out to be the ntsb would step in an outlaw them all one would think.
I do see the links posted are of low quality al. which id never think of to use, not even back in the old days on a sreet car, the third link also seems to use al, if you look further some of there better ones are steel.
This link I posted use one piece billet steel for there product, costs more but they seem to work well, at least for me, as for the extra loads if looked at on a perportional basis as well as other factors it could be said the ball is already rolling in that area the second the oem rims are removed and all different sizes and configs of aftermarket rims and tires are installed.
Old August 4th, 2012, 10:40 AM
After lifting my truck it was very top heavy.I bought a set of high quality aluminum 2" spacers and mounted them.It helped my stability issues and i have never had any adverse affects.It has been about 7 years now.
Old August 6th, 2012, 10:22 PM
If done right and you keep up with checking torque specs, like you should wheels anyway, they are fine. Yes they wear on parts more, but so do big tires and wide wheels and everything else fun. I know almost every single person that lifts an OBS or a newer chevy uses them in the back to equal out the track width. I'd buy quality like Skate did, but some people buy cheap and never have problems.
Old August 7th, 2012, 06:46 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
I dont have spacers and my chevy tracks straight
Black Sheep of FTC
adamfx4 , ASwaff400 , Bates88 , BigBlue79 , bikertrash3531 , Booba5185 , catmechanic07 , Flatbedmark , herbz , jrohner78 , Mhammers , ONELOWF , pocus , Russo2 , skatebowd
My Rant: Internet Ordering and UPS... My Bad Experience TedC General Discussion
0 January 16th, 2010 11:47 AM
Colleges ignoring military experience BigT67 General Discussion
1 August 21st, 2009 01:49 PM
experience , spacers , wheel
