Quantcast 1994 gauge cluster swap - Ford Truck Club Forum
Old April 21st, 2011, 09:16 PM
krick1961's Avatar
krick1961 krick1961 is offline
Question 1994 gauge cluster swap
im swaping out none tach cluster w/tach cluster part # f3tf-10c956 (came from circuit board) i belive this to be from 1993, my f150 is a 1994. when i do this my charging system fails. dose any one know what wires a need to swap? thanks for any help krick1961@comcast.net
Multi Quote REPLY GOOD POST
Old May 19th, 2011, 03:52 PM
subford's Avatar
subford subford is offline
1992 & 1993 are the same and 1994 & 1995 are the same.
The below images should let you find the wires to swap.
Bill K
95 F150 302 4R70W EB EX-CAB
83 F150 Flare Side 351W AOD
82 E350 RV 460-4V C-6
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Old May 19th, 2011, 04:44 PM
The key as stated above by Sub is that the 1992 and 1993 clusters are interchangeable and the 1994 and 1995 clusters are also interchangeable but you CANT interchange a 92-93 with a 94-95. 1996 and up switched to OBD II so these wont work on any 1992 - 1995 OBD I system.
I did the tach cluster swap on my 1995 F150 with that of a 1994 F150. I noticed that the needles and guages though looked the same, once taken apart and out of the cluster casing were designed very differently.
The temp gauge on the 94 stays where it is or even rises a hair when the truck is shut off where as the one in my 1995 cluster would drop down to 0 when the truck was powered off. Another difference with the same gauge that I noticed was the 1994 needle had to be pried off where as the 1995 needle came right off, the way they were designed was very different.
One of these days I will put together a nice article with pictures of my cluster swap... stay tuned!
A little treat:
FYI I sent back those digital gauges and went with analog autometers, havent installed them yet.
Old May 19th, 2011, 05:29 PM
CrazyD's Avatar
CrazyD CrazyD is offline
Images: 198
thank goodness - analog with analog guages = the poop haha
02 F150 5.4L - Lots to come soon!
Old May 20th, 2011, 05:02 AM
good info & posting
Old May 30th, 2011, 02:23 PM
krick1961's Avatar
thanks for the replies, i was able to find a 1994 cluster
Old December 13th, 2011, 10:40 PM
bruewayne's Avatar
bruewayne bruewayne is offline
I have been looking for the wiring changes to install a f150 1993 cluster w/tach in my 1995 F150.
Noticed there were some photos on "subford" reply but unable to view. I have schematics for 1993 and 1996 and think I need to reroute 4 wires. I plan to Change the 93 cluster wiring and leave the truck connector stock.
Old December 13th, 2011, 10:51 PM
DoubleDee's Avatar
Images: 669
Howdy bruewayne, welcome to the family!
Yeah, that's kinda why we like to have members upload to our gallery. This is a good example. When something happens with the photos from another "source", that are inserted into a post, we don't get to see or have that wonderful info to share with everyone.
Well, since you have the schematics, and you've figured it's just 4 wires to reroute, everything should hopefully work out. Take pics and post em up!
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
nine5flareside (December 30th, 2011)
Old December 29th, 2011, 06:57 PM
nightshade's Avatar
nightshade nightshade is offline
Default Fill in the blanks
What four wire did you relocate? I am trying to do the same thing...
Old December 29th, 2011, 08:23 PM
DoubleDee has gone TDY for a couple days, and may not have computer access
but I know he will be more than happy to help ya out
(View-All Members who have read this thread : 26
ASwaff400 , BigBlue79 , BigTrouble , bruewayne , CrazyD , DoubleDee , herbz , JSoko , KC9RFO , Klitch , krick1961 , Lostin90s , michaelsnodgrass18 , nflfreak43 , nightshade , nine5flareside , Roostertail , Russo2 , sbellinghausen , Scotts Black FX4 , skatebowd , subford , The Frankster , whitesleeper , Whitey , woodrock
1995 f150 Instrument Cluster Mod - TEASER nine5flareside 1992-1996 Ford F150
5 January 30th, 2012 11:10 AM
1994 ford 4x4 5.0` bigjohn New Member Introductions 2 February 12th, 2011 09:00 AM
Just did the cluster and a/c switchs.. b2therad 1997-2003 Ford F150
54 April 8th, 2010 05:18 PM
How To Center Shift Pointer Needle In F150 Instrument Cluster DIXIE FIX Garage Talk: Shop Class 101 5 November 28th, 2009 05:42 PM
1994 , cluster , gaudge , gauge , swap
