Quantcast Oil Pan gasket replacement - Ford Truck Club Forum
Old September 20th, 2012, 06:13 PM
HiRoller's Avatar
HiRoller HiRoller is offline
Default Oil Pan gasket replacement
Hello All, as stated in another post, my oil pan gasket has been leaking for a few years now. Not so much with in town driving but pretty good on a hiway trip. I find most say you can't pull the pan completely off the engine without pulling it out. I recall seeing some info awhile back on a method of leaning the engine side ways enough to get the pan out ??? any one know of this ?
I have seen the "drop enough" to get the gasket changed method but I wanted to go further with some cleaning.
Old September 20th, 2012, 06:27 PM
you'll have to get pretty high for a removal
a few other members have just done this recently
I forgot what your driving and engine size
Old September 20th, 2012, 06:30 PM
I just went through this issue, dropped my pan 3 times before I bit the bullet and bought a hoist and a stand, no matter how much you jack up the engine, the exhaust will hold it from coming all the way up, and the engine will hit the firewall.
Old September 20th, 2012, 10:29 PM
If you disconnect the exhaust, remove the upper intake plenum, and a few other things, it is POSSIBLE, althought FRUSTRATING. Very FRUSTRATING. Very Very FRUSTRATING. I had to do it on my 1989 5.0, and trust me, you want to pull the motor, it's just a bit more work and a LOT LOT LOT LOT less frustrating.
Old September 23rd, 2012, 10:40 PM
jones03100's Avatar
jones03100 jones03100 is offline
Images: 12
i did this on my 93, me and my dad was able to fish it through with zip ties and it worked great but it was a molded rubber one id say the cork style would just tear
Old September 23rd, 2012, 10:44 PM
Yea, don't skimp on the gasket, get the molded one peice rubber from Felpro, and make sure you put black rtv at the 4 corners, on each side of the timing chain cover, and on each side ofthe rear bearing cap.
Old October 15th, 2012, 10:45 PM
MetallateM's Avatar
MetallateM MetallateM is offline
Hey guys, This is my first post, just want to say hi and love this site.
I need to do mine too,i had a quick look a few days ago and thought it would just come right out.
Is it on all trucks? 2x4 and 4x4?
Thanks
Mike
Old October 15th, 2012, 10:56 PM
What year are your trucks?
Old October 15th, 2012, 11:21 PM
MetallateM's Avatar
mine is a 1992 4x4 5.0
Old October 16th, 2012, 10:08 AM
MetallateM;
get under there and look
the oil pan depth covers the crank botton
think how when you take the pan loose as to how high the engine will have to be raised to install a new one piece gasket
not to mention the cleaning of the two surfaces
Adrien , BigBlue79 , bikertrash3531 , Booba5185 , Bulldog74 , C-DogAK , cblachly7808 , HiRoller , jared96 , jones03100 , JSoko , Lostin90s , MetallateM , michaelsnodgrass18 , rick wilcoxson , rikard , Russo2 , The Frankster
1995 F150 - Blown Head Gasket nine5flareside 1992-1996 Ford F150
17 August 21st, 2012 02:52 PM
9" carrier gasket question BigBlue79 1980-1986 Ford Bronco
5 December 24th, 2011 03:13 PM
Blown Head Gasket 7.5 460 DIXIE FIX Garage Talk: Engine & Drivetrain 5 January 17th, 2011 07:38 AM
Tie Rod Replacement DavidS827 1997-2003 Ford F150
5 September 9th, 2010 05:30 PM
LED replacement bulbs RedHot150 2004-2008 Ford F150
16 August 20th, 2009 08:39 AM
gasket , oil , pan , replacement
