Quantcast Bad engine wobble - Page 2 - Ford Truck Club Forum
Old December 2nd, 2012, 12:02 AM
Some of the best 302 blocks came from Mexico. Higher nickel content and better main bearing caps. Pulling the radiator proved to be beneficial. I found some spots on the ribs where they were pressed over and decided to gently open them back up. I also did some recon on the Powerbond brand of balancers. They are a company in Australia that makes new balancers called Precision Parts. They are not reman at all. They also have their hands in manufacturing balancers for different applications from street, race, and SFI approved balancers and pulleys. Idk, if Dorman or other suppliers actually make new balancers or just reman them.
http://www.precisionparts.com.au/products.html
Old December 2nd, 2012, 02:53 AM
AFAIK Dorman just reconds them. IDK how exactly just what I've heard.
Old December 2nd, 2012, 09:59 AM
check out the, Pro Products Damper/Balancer 80006
Old December 2nd, 2012, 05:26 PM
Nice balancer J but its almost twice the price i paid for the Powerbond plus according to it's description I'd need an adapter to use it. Unless i was using an early 302.
Old December 2nd, 2012, 06:49 PM
did'nt think about that
and sine your not building for performance what you have will work just fine
good luck with your Truck
Old December 3rd, 2012, 10:09 AM
Thanks.
  #17
Old December 3rd, 2012, 09:53 PM
Not trying to but i also noticed these balancers are made of SG Iron.
Definition of SG Iron.
An abbreviation for Spheroidal Graphite Cast Iron. As the name implies, graphite is present in spheroidal form instead of flakes and compared with Grey Cast Iron it has higher mechanical strength, ductility and increased shock resistance.
Sounds like the perfect material for a damper or balancer.
  #18
Old December 10th, 2012, 10:45 PM
Really thought i had this solved. This past weekend I spent a lot of time under the hood fixing numerous thing. Changed TPS, new MSD Cap and rotor, new plugs, Rubber vac line swap, new EVP sensor, cleaned MAF sensor. Checked and rechecked timing. The wobble has worsened. The engine seems to be running awesome despite this. No knocking or anything. The shaking is bad enough that my dash and passenger seat moves. I have checked the flexplate for its counterbalance weight, for tightness in the TC nuts, and any wobble or play. The new balancer spins true while engine is running. Timing is set at 12° BTDC, plugs gapped at. 055". I've been in contact with Booba and Blue with this for the last coupla days and we all seem to be scratching our heads on this one. Some of the things mentioned to try next are:
Checking the injectors.
One way i was told was to use my looong 1/4"drive extension as a stethoscope to hear each individual click. Another way i found was to do a Cylinder Balance self test . Here's a link.
http://sbftech.com/index.php/topic,2471.0.html
Balancer slip
i read on a few other Ford based forums that a balancer can slip thus changing its counterbalance high point. I went out to the garage to get a reference as to where the keyway on the front of the cranckshaft is in relation to the centerpoint of the flexplate counterbalance. Just by eyeballing it the look to be in the same position. Tomorrow i will use one of the old balancers marked with the keyway position and reference the new balancer as to its position with the flexplate weight visible at 6 o'clock. Hopefully this tells me something.
Internal transmission issue.
Blue and I have kicked around a coupla ideas about an internal trans issue such as the pump, input shaft, etc. Right now i think it's a shot in the dark.
Engine is bad.
As much as i hate to admit it, this maybe the case. Right now the engine runs great, no knocking or anything. Just a soft Thud that's in sync with the vibration at the engine/trans union. So i think. Hard to really tell.
Engine mounts.
I will admit the engine mounts aren't the worst, but my belief is even if they were totally bad the engine if balanced, timed, tuned, properly would not shake the way it does. Yes it would rock under acceleration with a minimal vibe at idle but not like this.
Well, there you have it. What I've done, what's been discussed, and what I'm worried about. Please, if anyone has any insight, speak up. It would be greatly appreciated!
  #19
Old December 11th, 2012, 10:25 AM
if all fails
you should remove and check the crankshaft
which upon removal may show something else - bearings, rods, pistons, pins
  #20
Old December 11th, 2012, 11:06 AM
Just curious. If it was the crank wouldn't i have some sort of wobble at either end? At the balancer in front or the flexplate in back? Also wouldn't my idle quality be diminished some?
(View-All Members who have read this thread : 25
adoporto , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , catmechanic07 , cools , DoubleDee , HawaiianF150 , HiRoller , JSoko , Klitch , lanejesse85 , matt0106 , michaelsnodgrass18 , Moore1991bronco , nflfreak43 , nine5flareside , retired , rick wilcoxson , rikard , Russo2 , skatebowd , The Frankster , volvering
Death Wobble? Anybody know? BIGCOUNTRY Garage Talk: Engine & Drivetrain 18 October 15th, 2012 07:23 AM
Fixed death wobble - VIDEO EpicCowlick 2011-2016 Ford F250 | F350
4 August 24th, 2011 11:09 AM
Death wobble.... lil_bizzy 1997-2003 Ford F150
5 February 28th, 2010 07:46 PM
death wobble The-LI-Redneck Garage Talk: Shop Class 101 29 January 3rd, 2010 08:42 PM
bad , engine , wobble
