Quantcast FX4 wheel swap - Ford Truck Club Forum
Old May 6th, 2013, 01:58 PM
superdutydude2's Avatar
superdutydude2 superdutydude2 is offline
Default FX4 wheel swap
My 01 F250 has the stock 16" steel rims with 235 85 R16
My new 06 has the 17" wheels that come with the FX4; 265 70 R17
overall mounted diameter is about the same at around 31"
any problem swapping wheels between these trucks?
I like the narrower OEM type tires (quieter, better in snow, cheaper)
The 17's are very deep dish with the mounting plane near the outside.
Any other difference in the track width or steering clearances between stock and FX4?
Old May 6th, 2013, 03:50 PM
Do they both have the same number of lugs and the same bolt pattern?
Old May 13th, 2013, 03:53 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
They will mount up. The bolt pattern (8x170mm) is the same on both wheels. That bolt pattern was used from 99-Current model years. However, in 2005 with the change to coil over suspension, the axle was widened and subsequently the offset on the wheels changed. You will note an approximate 2 inch difference between the two offsets. You could
1) Run the wheels as they are. Your footprint will narrow by 4 inches.
B) Buy quality 2 inch spacers.
3rd) Swap the axles from an 05-07 truck. Its less work than you might think
2002 F250 7.3 CCSB 4x4
It has mods.
A/Ox4 , ASwaff400 , bikertrash3531 , Booba5185 , DoubleDee , glc , Hazzardousmat , JSoko , Russo2 , superdutydude2 , TPBull , TwoStroke
Need a new wheel and an alignment DoubleDee Garage Talk: Wheels & Tires 24 September 22nd, 2012 12:14 AM
Steering wheel MOD TFH Kane 1997-2003 Ford F150
2 March 21st, 2012 09:29 AM
steering wheel swap? ASwaff400 1992-1996 Ford F150
2 January 10th, 2010 11:02 PM
fx4 , swap , wheel
