Quantcast transmission installation - Ford Truck Club Forum
Old May 25th, 2013, 03:45 PM
MIkes 65 Ford's Avatar
MIkes 65 Ford MIkes 65 Ford is offline
Default transmission installation
OK I finally got the flywheel straighten out. I installed the flywheel, clutch and pressure plate. Remove the clutch alignment tool bolted on the bell housing and TRIED to install the transmission. I bolted four 7/16"-14 All threads about six inches,long into the bell housing as an alignment tool ,I slide the transmission in place but, I get stopped approximately 1 1/2" away from mating the trans to the bell housing. I've worked on this for the past two days and am getting no where..... Any Ideas?
Old September 17th, 2013, 12:09 PM
orich's Avatar
orich orich is offline
Images: 1
Hmm put trans in gear turn the rear tailshaft slow while pushing the tranny forward.
The splines is not lined up. I Always have a stick tranny placed in gear when installing them. If you can't turn the tailshaft use the driveline yoke.. my 2 cents.. orich
Old September 17th, 2013, 07:30 PM
TwoStroke's Avatar
TwoStroke TwoStroke is offline
If what orich said doesn't work. Make sure the splines are correct and check to make sure the tranny splins aren't bured. Sometimes they get messed up when there out
"Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young."
-Henry Ford
“The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.”
-G.K. Chesterton
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , carbineone , glc , jjanow2000 , JSoko , Malcolm , MIkes 65 Ford , orich , Russo2 , Scorekeeper58 , TwoStroke , tylerbotts
Transmission tag information 90f150xltcenturion Garage Talk: Engine & Drivetrain 1 February 1st, 2013 07:44 PM
55 223 six od Transmission John Lightcap 1948-1983 Ford F100
2 October 14th, 2012 10:23 AM
transmission little dave 1973-1991 Ford F150
10 July 31st, 2012 08:14 PM
E4OD 2wd Transmission bikertrash3531 Auto Parts For Sale
0 July 20th, 2012 09:33 PM
auto transmission joseywales 1948-1986 Ford F250 | F350
9 June 27th, 2012 12:49 AM
installation , transmission
