Quantcast STIFF gas pedal - Ford Truck Club Forum
Old November 15th, 2013, 12:00 AM
blueford's Avatar
blueford blueford is offline
Default STIFF gas pedal
i have a 92 with a 302 in it, and my gas pedal is about as stiff as can be! ive had to replace 2 throttle cables in it already due to them breaking, i had to put a new throttle body on the truck when a tin cup pressed into the side wore out and spewed coolant every where and when i put in a new tranny i made sure all the cables where adjusted right via a tranny shop in town, but the pedal is still harder the heck to push down, by unhooking the shift down cable it makes it soft like it should be but then of coarse you cant drive with it off, why is my pedal so stiff? i see alot of you have upgraded to a BBK throttle body, what is the advantage of that over the stock one? and might that solve my problem or is there another solution to fix it? thank you in advance!!!
Old November 15th, 2013, 10:46 AM
did it just start when you had the work done ?
Old November 15th, 2013, 11:15 AM
The TV cable to the Trans may have some cracking and fraying going on causing the cable to bind. If you haven't already done so, replace it. The BBK TB's have wider openings to allow more air in and the mechanisms are most likely better quality than wore out stock. I don't know how the EEC will handle the extra flow in a MAP/ Speed Density setup like yours. I'd think it would lean things out at least.
Old November 15th, 2013, 06:16 PM
blueford's Avatar
ok, thanks for the info on the bbk TB, and no this has been a problem with the truck since i bought it, ive replaced both cables and th throttle body also due to unrelated problems, and its still stiffer then heck! and as far as the map system in my truck i am working on getting a MAF sensor from a junkyard to mod into my k and n cold air intake and when i find it and ill order the harness to wire it in to my truck :)
ajcarson11 , bikertrash3531 , blueford , Counterfit Cash , F150GT , glc , JSoko , nflfreak43 , yahnke
hissing noise coming from brake pedal malvarez58 Ford Expedition 4 September 26th, 2013 10:22 PM
How to remove steering column and pedal assembly 87-91 Russo2 Garage Talk: Shop Class 101 7 January 8th, 2012 11:11 AM
Pedal assembly is fubar! Wiper motor is too!! Russo2 1973-1991 Ford F150
11 January 5th, 2012 10:15 PM
gas , pedal , stiff
