Quantcast Front driveshaft trouble - Ford Truck Club Forum
Old March 28th, 2015, 07:44 PM
Boomer's Avatar
Boomer Boomer is offline
Default Front driveshaft trouble
I have a 1977 f150 4x4 The u joints are good, but when you grab the front driveshaft (while in place) you can move it up and down or side to side. if you try too turn the driveshaft no play. I am sure this is not good but what do I do can it be fixed or do I look for a new one. And where do I find one.
Help
Thanks
Old March 29th, 2015, 09:57 PM
You sure the play isn't in the transfer case or front axle?
Old March 30th, 2015, 08:10 AM
Boomer's Avatar
Thank you for your comment. We removed the driveshaft. The play is at the slip yoke I'm new to all this maybe this is normal
Boomer , glc , harrison28 , jake3247 , Ozzie , Russo2 , Steve
79 bronco driveshaft issues Stuart Tinker 1978-1979 Ford Bronco
1 January 3rd, 2014 12:47 PM
Ford Bronco Double Cardan driveshaft rebuild BigBlue79 Garage Talk: Engine & Drivetrain 0 December 7th, 2012 12:12 AM
1997 F350 4x4 Front Axle Swap to 1998 4x4 front axle HARLEY589 New Member Introductions 13 January 27th, 2012 10:52 AM
How To: Greasing the rear Driveshaft Slip Joint in a 1980-1986 Bronco BigBlue79 Garage Talk: Shop Class 101 0 October 13th, 2011 02:49 AM
driveshaft , front , trouble
