Quantcast Trouble Starting the Truck/Car? Replace the Coolant Temperature Sensor - Ford Truck Club Forum
Old July 19th, 2012, 07:07 PM
Question Trouble Starting the Truck/Car? Replace the Coolant Temperature Sensor
Visually inspect the engine coolant sensor because it may not set off a trouble code.
If you have starting problems and the "check engine" light doesn't come on, you may have a bad engine coolant temperature sensor (ECT). They're quick and easy to replace.
1. Bad sensor causes cold starting problems
The Sensor could be cracked (the part that goes in the flow). A cracked sensor won't set off a trouble code or “check engine” light. But you may have to pump the pedal to keep the engine running.
If you have to pump the gas pedal in the morning to keep your car running, you may have a bad engine coolant temperature sensor. The computer in every fuel-injected car must know two things before it can figure out the correct cold-start air/fuel mixture: the engine coolant temperature and the outside air temperature. Your symptoms are a dead ringer for a bad engine coolant temperature sensor (ECT) . The computer is calculating an air/fuel mixture that is too lean. That’s why pumping the gas pedal keeps your engine running.
You can have a bad sensor even without a “check engine” light or trouble code. I could tell you how to test it, but they’re so cheap (about $15) and easy to replace, that it makes more sense to just replace it. Ask the auto parts store clerk to find the right sensor for you (you may have two—one for the computer and one for the temp gauge on your dash) and to show you where it installs on your engine. Local Parts Stores a getting better a helping the DIY customer
ALEXB , BigBlue79 , bikertrash3531 , Booba5185 , cowguy , HiRoller , JSoko , michaelsnodgrass18 , windigowolf
How to Choose Engine Coolant JSoko Garage Talk: Shop Class 101 0 February 28th, 2012 11:49 PM
Trouble Starting Diesel Truck in Cold Weather JSoko Garage Talk: Shop Class 101 0 February 22nd, 2012 09:53 AM
how to replace heater hose under manifold on ford f-150 truck 4calico 1997-2003 Ford F150
2 July 22nd, 2011 12:59 PM
1998 F150 Coolant Change DIXIE FIX Garage Talk: Shop Class 101 13 April 16th, 2010 05:34 PM
Prison log: Execution trouble due to drug use BigT67 General Discussion
0 September 16th, 2009 09:48 PM
coolant , replace , sensor , starting , temperature , trouble , truck or car
