Quantcast Strange Noise When Opening Door - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-100 | F-150 SERIES > 2015-2020 Ford F150
Old May 1st, 2019, 08:05 AM
Question Strange Noise When Opening Door
New 2018 F-150 Super-Cab, only 1200 miles driven
went to the Dealer, did not make the sound
questions asked:
auto running boards - NO
easy down tailgate - NO
does passenger lock button up top by window move - NO
auto lock tailgate without key hole - YES
almost each time I open the driver door here is a clicking sound (about 6 times - did did did did did dit) that comes from the center of the Truck on the passenger side
took Truck to the Dealer, I could not make the sound happen
it does not happen opening the door repeatedly, only after the truck has sit for say 30 minutes
any ideas
Old May 1st, 2019, 07:31 PM
its a Ghost
Old May 6th, 2019, 06:22 AM
could be Skate
well spending more time in the Truck i have noticed that when I sit in it after the engine is off and the radio plays for a few minutes
when the radio stops playing I turn the key to ignition to play the radio I hear the sound
HELP any ideas???
Old May 13th, 2019, 11:18 AM
found my answer on another site FORDF150.net and also on the internet
apparently the sounds is the Fuel Pump turning on when the door opens
something to do with Direct Injection
I have called 2 Dealers and no one knows
Old May 13th, 2019, 11:46 AM
That is strange. Maybe the fuel system starts priming as soon as you open the door?
Old May 13th, 2019, 12:13 PM
yes it does, something about this new direct injection
they hooked it up to the door instead of when you turn the key
so you have an instant start-up
Old May 13th, 2019, 12:19 PM
here's some info I found
Just so it's clear, the 5.0 also has the same direct injection and port injection for 2018. All engines do except the 3.3. The prime on door open allows the fuel system to bleed down which prevents the early failure of the HPFP shaft seal. Conversely the pump needs fuel immediately or else it will destroy itself from a dry start. Being tied to the door it gives the truck time to actuate the pump before the key is turned. The delay was not built in to the key because of a possible nuisance delay situation. Also if you remote start a 2018 there is a delay for the fuel pump built into the strategy. This is how it was explained to me by a Bosch systems engineer during a trade event. Other manufacturers are doing it also.
Its the fuel system building pressure. Do a search on it. It's supposed to release pressure from the injectors when it sits for an extended period and when you open the driver door it builds the pressure back up to enable you to crank the truck
harrison28 (May 13th, 2019)
glc , harrison28 , JSoko , skatebowd
Beeping noise Rebelrider60 1992-1996 Ford F150
2 August 4th, 2018 02:10 PM
Front end noise?? MJB246 1992-1996 Ford F150
2 September 4th, 2017 05:27 AM
Loud noise, possibly from Brakes fordtruck99dually 1999-2007 Ford F250 | F350
2 September 16th, 2012 12:10 PM
Intermittent Grinding Noise TedC 2004-2008 Ford F150
4 October 18th, 2010 01:28 PM
Clicking noise? V8_Feller 1997-2003 Ford F150
15 January 1st, 2010 05:33 PM
door , noise , opening , strange
