Quantcast 99 f250 5.4 p1131 - Ford Truck Club Forum
Old November 6th, 2019, 03:14 PM
Jrp79's Avatar
Jrp79 Jrp79 is offline
Default 99 f250 5.4 p1131
99 f250 5.4 with a 03 pi 5.4 engine swap.idles good drives good if driving normal.if i accelerate more then 1/2 throttle driving or idle it skips. Only code is p1131.
Someone put warn hubs so i removed the vac lines from the canister to the wheels.replaced all connections that were bad.all lines are hooked up.ac and heat blows out of any vent i select.gas cap looks good, oil dipstick and cap are tight. No holes in the air intake tube. Im stumped on what to check next.
Oem ford cops,new oem platinum plugs.
Old November 6th, 2019, 04:27 PM
Jrp79's Avatar
My ff data
Fuel system 1......cl-fault
Fuel system 2......cl-fault
Cal load.........81.96
Ect........181
Stft b1.....5.47
Ltft b1.....5.47
Stft b2......5.47
Ltft b2......5.47
Eng rpm...2202
Veh speed....22
Not sure if any one can tell me by reading that data whats going on
Old November 6th, 2019, 07:56 PM
Liked 113 Times in 109 Posts
You have more stuff to check. There's a lot more things other than a vacuum leak that can trip that code.
https://www.troublecodes.net/p1codes/p1131/
harrison28 (November 7th, 2019)
Old November 6th, 2019, 08:48 PM
Jrp79's Avatar
Does any one have the specs on how to test the maf with a volt meter(how to and what readings should be)
(View-All Members who have read this thread : 25
AlfredHof , BennyloR , Danielfuh , DannyHog , Derrickquiva , Edwardvor , ElzaWhomo , fairyfub , glc , harrison28 , Jamesdualk , Jamesjeady , JeffreyKeX , Jrp79 , JSoko , LeonelCox , Melissazoomi , PhilipEtess , Raymondagozy , Robertcem , RobertEmavy , RonaldFon , TimothyNut , WayneNEX , Williamtaf
'86 F250 I6-300 blissrt New Member Introductions 4 April 10th, 2017 01:54 PM
89 F250 2WD to 4WD ArmyVet 1987-1991 Ford F250 | F350
6 October 13th, 2015 08:55 AM
New toy f250 2wd Tr00b 1948-1986 Ford F250 | F350
5 July 18th, 2013 11:09 PM
03 f250 egr swilliam691 1999-2007 Ford F250 | F350
4 May 3rd, 2012 07:49 PM
P401 and p1131 BigTrouble 1997-2003 Ford F150
10 April 10th, 2011 07:15 PM
f250 , p1131
