Quantcast ABS Speed Sensor (Front) - Ford Truck Club Forum
Old April 28th, 2019, 12:32 AM
SallyMiller's Avatar
SallyMiller SallyMiller is offline
Default ABS Speed Sensor (Front)
I'm trying to replace the front left speed sensor on my motorhome with 2001 F450 Superduty chassis.
The location of the sensor on my Superduty chassis does not seem match any of the U tubes that address replacement of the part. The U tube videos show that the entire wheel hub must be disassembled to pull the speed sensor, but when I look at wiring leading to the sensor, it seems that I should be able to pull it from the backside of the wheel assembly by removing one bolt, without even taking the tire off. It's stuck in there pretty tight due to corrosion, so I don't want to start banging on it if it's not going to do any good.
Any thoughts would be greatly appreciated. Thanks in advance.
Old April 28th, 2019, 10:45 AM
Liked 114 Times in 110 Posts
I have no idea, but I'm thinking there may be a difference between 2wd and 4wd?
glc , harrison28 , SallyMiller
Knock sensor MickJr 1973-1991 Ford F150
3 March 20th, 2017 09:13 PM
Speedometer/Speed sensor/Shifting problems jleerider 1997-2003 Ford F150
1 May 21st, 2013 01:43 PM
1997 F350 4x4 Front Axle Swap to 1998 4x4 front axle HARLEY589 New Member Introductions 13 January 27th, 2012 10:52 AM
speed sensor issues fightlife1437 1997-2003 Ford F150
5 December 26th, 2011 06:47 AM
abs , front , sensor , speed
