Quantcast AOD or E4OD? - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: Engine & Drivetrain
Old January 9th, 2019, 03:26 PM
Default AOD or E4OD?
My 91 single cab, long bed, 4x4, F-150 that I recently did the motor swap in originally had a fuel injected 302 with an automatic transmission. Is there away I can tell which of the 2 autos it was by looking at the transmission? It originally had an "OD Off" button on the dash to the right of the steering column. It's also a single fuel tank truck. Not sure if any of that helps or not.
Old January 9th, 2019, 04:01 PM
Liked 85 Times in 82 Posts
If it has the button, it's a E4OD. Quadrant should say PRND21. AOD quadrant is PRN(D)D1.
E4OD pan is shaped like the state of Utah. AOD pan is rectangular.
harrison28 (January 9th, 2019)
Old January 9th, 2019, 04:56 PM
Thanks for your quick response and knowledge GLC. I found an E4OD at a local bone yard for $400. Think I might put one back in the truck. Just wanted to make sure the truck's computer would be happy.
Old January 9th, 2019, 06:58 PM
I think it has to be out of a same generation F150 4x4 with a 4.9, 302, or 351W. Other configurations will probably not work. There's bellhousing patterns and tailshaft configurations to deal with.
Old January 10th, 2019, 10:13 AM
I'm gonna measure the bellhousing bolt pattern before I buy it. As long as it has the tail shaft extension for a transfer case is still on it, I'm confident the t-case bolt right up. I still have the t-case that was on the auto originally.
Old January 11th, 2019, 09:00 AM
The Bone's Avatar
The Bone The Bone is offline
Liked 3 Times in 3 Posts
If you are going to buy a used transmission, I would suggest having a transmission shop take a look at it before you install it. Nothing like installing it and it needs to be rebuilt. Its money well spent.
harrison28 (January 14th, 2019)
Old January 14th, 2019, 12:13 PM
Good advice.
(View-All Members who have read this thread : 4
glc , harrison28 , meyoung , The Bone
E4OD transmission trouble 96 f150 4x4 1992-1996 Ford F150
2 April 6th, 2017 10:15 PM
E4OD Tranny Trouble Beau109 1992-1996 Ford F150
2 June 24th, 2015 03:33 AM
E4OD 2wd Transmission bikertrash3531 Auto Parts For Sale
0 July 20th, 2012 09:33 PM
E4OD Trans Slipping nine5flareside 1992-1996 Ford F150
3 July 27th, 2010 08:34 PM
E4OD acting crappy in OD. nflfreak43 1992-1996 Ford F150
5 May 16th, 2010 08:10 PM
aod , e4od
