Quantcast 89 F150 - Ford Truck Club Forum
Old March 8th, 2018, 04:17 PM
sss's Avatar
sss sss is offline
Default 89 F150
STARTS THEN DIES WHEN IT WARMS UP then will not start again tell its cool
Old March 8th, 2018, 09:26 PM
Images: 243
Liked 30 Times in 30 Posts
welcome, put in forum that corresponds with your vehicle
Old March 8th, 2018, 10:45 PM
Liked 43 Times in 40 Posts
Thread moved.
Sounds like an ignition module that dies when it gets hot.
Old March 9th, 2018, 03:17 PM
sss's Avatar
sss sss is offline
changed that plus new fuel pump n filter air fiter sparks plugs cap rotor coolant sensor airintake sensor oil pressure sensor coolant switch maf sensor tfi module throttle position sensor water pump thermostate cleaned throttle body n idle contol n change selinoid changed oil radiator flush heater core change out voltage regulator change few things changed i could have missed
Old March 19th, 2018, 04:16 AM
sss's Avatar
sss sss is offline
Default high pressure fuel pump
would a bad high pressure fuel pump cause my 89f150 5.0 302 to die after the truck warms up
Old March 19th, 2018, 10:32 AM
Maybe. Test the fuel pressure.
glc , Hamilton Fordy , harrison28 , JSoko , Monkeyfinger , skatebowd , sss , The Bake
f150 , fuel , high , pressure , pump
