Quantcast What is the lift height here? - Ford Truck Club Forum
Old December 28th, 2016, 11:33 AM
TBufkin's Avatar
TBufkin TBufkin is offline
Default What is the lift height here?
I found a very good looking f150 truck, it's got pretty much everything that I want for my own project and need your help to figure out what is the wheel size and the lift here. I found the picture on google but unfortunately no sizes were present.
I believe the wheels are 35 and the lift is 3-4", but I can't tell for sure, do you guys have any idea?
Old December 29th, 2016, 10:55 AM
It's probably a 3" or 4" lift in the front and 1" or 2" in the rear to level it out. Without a good program to clear up the image when blowing it up, it's hard to say about the tires. I would guess they might be 33's.
Old December 30th, 2016, 10:24 AM
TBufkin's Avatar
Thanks! I thought the lift should be equal on the front and the back like 3-4" front and 3-4" rear. Is there any reason why do you recommend only 1-2" on the back?
Old December 30th, 2016, 10:52 AM
That was not a recommendation, it was an observation. At stock height there's some rake, the back end is higher than the front. That does not appear to be the case here, if anything the back end is lower than the front.
Old January 4th, 2017, 12:00 PM
TBufkin's Avatar
Ok if I got you correctly I can get a kit like this https://www.carid.com/2013-ford-f-15...296361169.html with 4" lift on the front and 2.5 on the back and I will have all pretty much leveled up?
Old January 5th, 2017, 09:31 AM
That should do it.
glc , harrison28 , JSoko , larrhy2 , TBufkin
Someone who knows where i could get a lift kit? Ford-f250 New Member Introductions 13 February 14th, 2012 10:11 PM
Lift for 02 Scotts Black FX4 Ford's Not Listed 5 September 17th, 2011 12:59 AM
new lift The-LI-Redneck 1992-1996 Ford Bronco
6 September 15th, 2010 03:59 PM
Lift LilBit 4x4 General Discussion
9 October 28th, 2009 08:48 AM
Ranger Body Lift versus Suspension Lift TazDevil07 2001-2011 Ford Ranger
21 July 12th, 2009 01:17 AM
height , lift
