Quantcast Gauge issues - Ford Truck Club Forum
Old April 18th, 2019, 11:15 PM
Sam442's Avatar
Sam442 Sam442 is offline
Default Gauge issues
Hello, new to the forum. New to me 66 F100, 352, 3 on the tree.
Fuel and temp gauges read full scale. Performed continuity check from fuel sender to gauge. All good. Tested sender with ohm meter. All good. Cleaned grounds. With some searching and googling, I checked the voltage regulator on back of instrument panel. Was getting 12v in and 12v out. Picked up a new regulator (NPD 10 minutes from my house). 12v in, 8v out, gauges still pegged. Am I missing something? I read that the output is sweeping and I am using a digital multimeter. Any guidance on what else I could check would be much appreciated.
Thanks and looking forward to working on this thing!
Old April 19th, 2019, 04:03 PM
JedCrone's Avatar
JedCrone JedCrone is offline
Liked 3 Times in 3 Posts
I'm having trouble with my '74 dash as well. Same symptoms. U have gone thru 3 different regulators. Maybe I just keep getting bad ones? I only have a digital multimeter too. This wont help but at least you know someone else is having the same problem
Old April 22nd, 2019, 09:44 AM
A descent digital meter should read a "sweeping" voltage as well. I use a $500 Fluke, but I am an electrician by trade. You could get by with a cheaper Ideal meter or Klein even. Just something other then the $20 auto zone deal. If possible, get an aftermarket gauge and hook it up temporary to verify all the circuits are working properly. You can always return it. This could help narrow down where you're exact issue is.
Old June 7th, 2019, 11:38 PM
Sam442's Avatar
Sorry for not posting and following up. Been working out of town and haven’t had a chance to look into this for a while. Until today...... still have fuel and temp gauge issues after installing a new voltage regulator behind instrument panel. Fuel gauge goes full scale even with sender unplugged and not touching anything. Decided to pull instrument panel to have more access, and now I have lost ALL power. I mean nothing! All fuses are good on fuse panel. Is there a main fuse that could have blown somewhere?? Any assistance would be appreciated so I can continue troubleshooting the other issues.
Old July 21st, 2019, 06:23 AM
RustyPile's Avatar
RustyPile RustyPile is offline
The gauges won't work if you're trying to check the gauges with the cluster removed from the dash until you establish a ground path.. Do this by using a jumper connected between ground circuit on the cluster and the body..
harrison28 (July 22nd, 2019)
Amoxlype , glc , harrison28 , JedCrone , jheat , Losvws , RustyPile , Sam442
3 July 21st, 2013 10:10 PM
Engine Temp Gauge 88f150 1973-1991 Ford F150
3 June 19th, 2013 11:41 PM
Gas Gauge ames8722 1973-1991 Ford F150
9 August 28th, 2012 07:36 PM
Looking for: Bore gauge Klitch Garage Talk: The Tool Depot™ 4 June 26th, 2012 03:10 PM
3 July 10th, 2010 09:39 PM
gauge , issues
