Quantcast crzyjunyer's crankbait fishing tips - Ford Truck Club Forum
Old August 13th, 2009, 12:15 AM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
Thumbs up crzyjunyer's crankbait fishing tips
My preffered method is to take the boat and head into the wind (easier to control boat direction adn speed and better for bait presentation ) and keep the boat 4-5 ft or so off the rocks depending on depth - i try to fish crankbaits that dive about 1-2' deeper than the water (like a 8' diver in water 6' deep) and crank slow bumping the lip off the rocks - i do get hung up some but i have learned to be patient and usually by just backing off and going on tothe lure and getting just past it they will usually float on up - usually just get wedged in between or under one and will come out the way it came in - you will also need to keep a close eye on your line near the lure for nicks and cuts - i try to check mine for major knicks on every cast and "feel" check every 5-6 casts for them
Big T
BigT67's Avatar
Images: 262
Originally Posted by crzyjunyer View Post
sure - my preffered method is to take the boat and head into the wind (easier to control boat direction adn speed and better for bait presentation ) and keep the boat 4-5 ft or so off the rocks depending on depth - i try to fish crankbaits that dive about 1-2' deeper than the water (like a 8' diver in water 6' deep) and crank slow bumping the lip off the rocks - i do get hung up some but i have learned to be patient and usually by just backing off and going on tothe lure and getting just past it they will usually float on up - usually just get wedged in between or under one and will come out the way it came in - you will also need to keep a close eye on your line near the lure for nicks and cuts - i try to check mine for major knicks on every cast and "feel" check every 5-6 casts for them
you ever try using a braided line?
Big T
Old August 13th, 2009, 01:19 AM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
I have been using Spider wire for years. I love braided, especially on my baitcasters and open face reels. Then again I dont even own a closed face reel. I used to use them for cat fishing but got hooked on the others for that too. I do the same with my crankbaits letting them knock off rocks. Seems to do pretty well around here mid-spring, late-fall, and winter for deep fishing. Stripers seem to do well with plugs in the winter months tho!
Black Sheep of FTC
Old August 13th, 2009, 08:02 AM
crzyjunyer's Avatar
crzyjunyer crzyjunyer is offline
no ive never liked braided line - ive pretty much gone to a newer brand line called "suffix" - i like it - good knot strength and good abrasion resistance - i just had too much truoble with braided to keep using it - i would either have a weak knot or get glue all over everythig trying to keep it tied - plus i tore a reel up trying to break loose when i used it on my worm rod - only time i use it now is a a buddy's private pond - he has 50# braided on his catfish rod - we just throw out a half a hot dog with a 1 oz weight - when the line moves - suppers up !!
an unloaded gun is just an expensive paperwieght
you cant fix stupid - but remove warning labels and we can greatly reduce its main offenders !!
WAR EAGLE
SmiliesFTW.com
Old August 13th, 2009, 08:48 AM
BigT67's Avatar
Images: 262
I don't know if you've seen these knots, but they work real well with braided line
Big T
Old August 13th, 2009, 03:53 PM
crzyjunyer's Avatar
yea i hve but im used to mono so much now that its not worth it to go back to me
WAR EAGLE
SmiliesFTW.com
Old August 13th, 2009, 05:24 PM
Ive always used the improved clinch knot
which looks similar to the braid knot above but with a single strand
its hard for me to re tie without glasses[6-10lb] and I wont take glasses with me
any other that are easier than the clinch
Old August 14th, 2009, 07:05 AM
I dont use braided line
I tie the hook with an Improved Clinch knot
but I dont wear glasses, and its hard to even thread the line through the hook eye, much less all the twist & loops
any easy hook knot for the blind??
Old August 14th, 2009, 09:58 AM
BigT67's Avatar
Images: 262
I use mono for my leaders and most times i use an egg loop knot for my hooks, because thats about the strongest hook knot you can tie. Joey, if you practice that knot at home several times a week, when you go fishing, it is easy to tie without having to see it too well.
Big T
Old August 14th, 2009, 11:11 AM
BigT could you show me the egg loop
good day of fishing? ASwaff400 General Discussion
9 May 17th, 2010 04:03 PM
Tips to Strengthen the Frame Gearz Gearz 1 May 1st, 2010 03:27 PM
Gone fishing? More Americans did in 2009 BigT67 General Discussion
1 March 23rd, 2010 04:56 PM
Late December fishing BigT67 General Discussion
9 January 3rd, 2010 08:37 AM
BassMaster Fishing marmaduke General Discussion
2 December 9th, 2009 05:13 PM
crankbait , crzyjunyer , fishing , tips
