Quantcast Cant find offset for factory rims on 92 flareside (f150) - Ford Truck Club Forum
Old January 18th, 2014, 05:59 AM
scsflareside's Avatar
scsflareside scsflareside is offline
Default Cant find offset for factory rims on 92 flareside (f150)
Im currently changing my stock rims which are 15x7.5" to something a little bigger, but I cant find out anywhere what the offset on my rims are. They are the original factory rims.
Old January 18th, 2014, 09:42 AM
Images: 243
Liked 34 Times in 33 Posts
by bigger you mean taller or wider or both?
Old January 18th, 2014, 01:13 PM
Generally factory wheels are offset at 0 for maximum life of bearings and suspension components. If you put your wheel face down and put a ruler or other flat surface across the top and take a tape measure and measure from the mounting surface to the ruler you will have your back space. If your wheel is 7.5" wide and your backspace is 3.75" your offset is 0. Aftermarket wheel companies measure offset metrically, so it will be in MM's if your backspace is 3.5" (.25" offset) it will be roughly a 6mm offset. Hope this helps
http://www.fordboltpattern.com/Ford_..._Patterns.html
Offset looks like 0-20mm. According to that^
Adsquared , BigBlue79 , bikertrash3531 , F150GT , glc , JSoko , KD-DET , knifeman , nflfreak43 , Russo2 , Scotts96 , scsflareside , skatebowd , The Frankster , Wolfe
Any pictures of 26" rims on a 09-12 F150? 2012HDSCREW 2009-2014 Ford F150
5 November 26th, 2012 11:33 PM
Cragar Soft 8 Style Ford F150/Bronco Rims BigBlue79 Auto Parts For Sale
9 July 5th, 2012 12:00 AM
2009-2012 Ford F150 Flareside Lighting Info HawaiianF150 Garage Talk: Electrical & Lighting 2 June 24th, 2012 11:46 PM
new f150 rims... tylerbotts Garage Talk: Wheels & Tires 0 March 23rd, 2011 10:09 AM
1995 F150 Flareside Pointless Burnout FordTruckClubTV FordTruckClubTV 0 February 23rd, 2010 11:51 PM
f150 , factory , find , flareside , offset , rims
