Quantcast Diablo Info For Cat - Ford Truck Club Forum
Old April 9th, 2010, 06:30 PM
Default Diablo Sport info for CAT
U7194 Stock Vehicle Tunes:
93 Octane Performance Tune
91 Octane Performance Tune,Corvette,G8 and Camaro only
87 Octane Performance Tune,Truck & SUV only
Modify Factory Tune
U7194 Specific Features:
COT time delay
DoD disable
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-4.9k / 5k-7k
Rev Limit
WOT Spark (in degrees) 1k-3.8k / 4k-5k / 5.2k-7k
Fan adjustment, individual adjustment per temp dependent cell
Tire Size
Speed limit(truck/SUV only)
Read/Write time is approx 60 seconds
Clear codes supported
Live data and log supported
Holds up to 5 custom tunes & Dat viewer is supported.
All standard DiabloSport Predator features
NOTE: This Predator will ONLY work on the new body style 2007 silverados
How to verify that the vehicle is supported
The eighth (8th) position in the vehicle identification number (VIN) is the code that designates the engine type. The Predator will support the vehicle if the engine code is:
2006-2007 Car: 8th digit of the VIN= U or E
2007-2008 Truck or SUV: 8th digit of the VIN= C, 3, 0, J, K, M, Y or 8
2009 Truck or SUV: 8th digit of the VIN= 0, 2, 3, C, ,K or M
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are per tune. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
BATES
Banks & PHP Powered
Old April 10th, 2010, 07:31 AM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
Thanks for the info Bates. So the Predator is a plug and go tuner? I know the one for the Fords was one ya had to do this and that to or am I wrong? I dont know much about that stuff so Im lost.
Mini Exploder.....guess it just gets wheels and new rubbers. Maybe a few little things to make it stand out. I told her she shoulda bought a Chebby...lol! Of all things....she wants to trade it on a Honda Pilot. Oh well.....her payments....NOT MINE!
Black Sheep of FTC
Old April 10th, 2010, 02:14 PM
Plugs into the OBDII port, download stock, upload aftermarket program and away you go.
BATES
Banks & PHP Powered
Old April 11th, 2010, 09:35 AM
Images: 25
So when I purchase it....It will be ready to plug in and I follow on screen instructions or Is it true Plug n play with everything already downloaded? Im tellin ya Im lost but I want it so I dont loose all my power with the tires and lift. I may get with you and just order thru your company so I know Im getting what I want and need so my truck runs ok. Thanks for the help
Black Sheep of FTC
Old April 11th, 2010, 02:27 PM
Plug in, download (follow easy instructions) stock tune, choose aftermarket program (tow, economy, performance) and upload. Or you can fine tune also with tire sizes, speedo, rev limiter, etc.....
At the most you might have to update it to a newer version but that can be done directly from their website.
BATES
Banks & PHP Powered
Old April 11th, 2010, 04:40 PM
Images: 25
Cool! Thanks
Black Sheep of FTC
Old April 11th, 2010, 10:51 PM
No prob Bro!
BATES
Banks & PHP Powered
Old April 21st, 2010, 11:25 PM
Images: 25
Any promo codes you can give me to get a discount?
Black Sheep of FTC
Old April 22nd, 2010, 11:30 AM
Yep, Chebby went bankrupt and so did I when I bought one!
Sorry dude, got no promo codes for ya!
I would say though, buy it somewhere if for some reason you have any kind of problem you can talk face to face with somebody.
Even if you have a problem updating it (which you shouldn't) they could do it for you.
Easy to do but I will do updates for a lot of customers, for the computer illiterate.
Everything should be good for you CAT, you will like to have that F150 power once again.
BATES
Banks & PHP Powered
Old April 23rd, 2010, 08:10 AM
Images: 25
Ford power.......I lost any power I had when I put the 35's on it. I want some of my power, torque, and shift points after this lift is installed monday. Ill deal with it for a little while without but I want one before I go to the beach in august. Oh yeah.....I want to calibrate my speedo as well
Black Sheep of FTC
Bastien , BigTrouble
Need some info about bikes. LilBit 4x4 General Discussion
68 October 20th, 2009 04:44 PM
Balance Info JSoko Garage Talk: Shop Class 101 2 September 26th, 2009 12:49 PM
CB Radio Info.. LilBit 4x4 Garage Talk: Sound & Security 45 August 24th, 2009 04:32 PM
More Info on Sodini Bates88 General Discussion
1 August 5th, 2009 07:39 PM
Diablo Sport Predator Bates88 Garage Talk: Engine & Drivetrain 0 July 28th, 2009 01:34 PM
cat , diablo , info
