Quantcast Brake screw up - Ford Truck Club Forum
Old December 1st, 2014, 11:38 PM
The Frankster's Avatar
Liked 12 Times in 9 Posts
Default Brake screw up
My braking had not been what it was several months after doing the F350 conver. The only thing not new was rear drums. Bought a pair a few months ago, cleaned and painted them red and put back in box. Was planning on borrowing friends floor jack but the way I work and he works, just couldn't get together. So I used truck jack today and installed drums. I screwed up because I forgot to clean inside of drums. First braking was awesome, then second time came the vibration. It seems to be a little less after driving about 10 miles to store, but is there anything I need to do to remedy this, or will this go away with wear?
Old December 4th, 2014, 01:25 PM
it should go away
in my doings if I had a vibration it was caused by a worn cutter on the lathe from turning a drum or disc
Old December 4th, 2014, 07:14 PM
drive it like ya stole it for a while
Old December 5th, 2014, 07:34 AM
there is a certain bedding-in procedure for new brakes
I added an artical about this here but can't find it
see some of these
https://www.google.com/webhp?sourcei...20new%20brakes
Old December 7th, 2014, 08:45 PM
I read about that in Hot Rod about a year ago. I thought it only pertained to front disks. Anyway, I pulled drums off, cleaned real good and they looked and felt good. Cleaned shoes and noticed at the top and bottom of both leader and secondary a rough area. Took some fairly gritty sand paper and cleaned them up. Noticed at top of leader when I started sanding high and low spots. Got looking and feeling pretty good but still have vibration at times. Sometimes they are smooth as silk and on a hard brake, vibrates like hell. I think my only recourse is new shoes and have drums lightly turned. Not happy with the EBC's on front either. May change them too. I changed plugs today with side gapped ASF32 Motorcraft. Drove it just on a two mile round trip and seemed to notice a good difference. I also checked the timing and seems it went back to 10 BTDC. The new MSD has short wires so it is hard to get to 13. I was going to put it on 14 as I've read you can go all the way to 16. Reason for side gapped and timing increase, I went home to Tn Thanksgiving and only got a 1.5 mpg increase. Very disappointed. It has seemed to get far better city which is odd. Got timing on 13 for sure so I'll see. All 8 plugs were almost white as cotton with the exception of front and back on drs side. They were slightly a light beige. #4 was white so the PVC reroute worked great. Thanks Booba. Still looking for a 80 amp relay. I have found two now on ebay, but they are 5 pin. I understand the fifth pin is for running both speeds so I assume it will work. I sure hate changing those plugs on right bank, but I can do back now almost as easy as rest. Two short, 1med and 1 long extension with a swivel and out it comes. Been busy. Thanks for the replies and love the avatar J.(wish that was me at times.:) ) Oh, had my first real date last night and went well. Very special lady. Will try to get on here more. Hate to see the site so slow. Ya'll take care and have a good night.
Adsquared , glc , IrishKRO , JSoko , Russo2 , skatebowd , The Frankster , tierney2375
Having Issues with my 04 F150 5.4L Screw matttrox 2004-2008 Ford F150
1 August 1st, 2014 07:59 AM
Help with Exaust for 2002 screw gustavs409 1997-2003 Ford F150
18 January 18th, 2012 01:04 AM
04 Screw Lariat 5.4 boombox03 New Member Introductions 6 August 17th, 2010 10:35 AM
Pac Brake Air Bags Bates88 Garage Talk: General Tech Talk 0 November 19th, 2009 03:40 PM
2005 F150 Screw Fiberglass sub box/console build RJaeger Garage Talk: Sound & Security 19 July 10th, 2009 05:19 PM
brake , screw
