Quantcast Brake pedal drops to floor with no resistance - Ford Truck Club Forum
Old February 2nd, 2018, 07:59 PM
Longbeach4x4's Avatar
Longbeach4x4 Longbeach4x4 is offline
Default Brake pedal drops to floor with no resistance
I have a 1991 f150 with a GM Dana 44 with flat top knuckles in the front and the stock 8.8 in the rear.
Yesturday I did the rotors and pads drums and shoes, new hardware for shoes and f350 brake cylinders.
Planning on also getting a 350 M/C and booster but isn't currently installed. Before doing this my pedal was super stiff and I don't think it ever hit the floor when braking.
I also threw in some warn premium locking hubs.
Put my bfg back on bled the lines I have a bleeder kit and it worked like a charm when I broke a hard line and swapped my brake lines with ss from bronco graveyard.
If I understand correctly you bleed furthest from M/C
Passanger rear
driver rear
Passanger front
Driver front
RABS
When I was bleeding the rear pedal was getting stiffer and stiffer with every pump. When I went to bleed my front passanger all of a sudden my pedal is soft and spongy and travels further than 'normal'
Closed everythin up. Turned the truck on and the pedal sunk straight to the floor. When the truck is off the pedal is super stiff like it was before but when I try to drive pedal goes to the floor. The truck stops but I'm not about to get on the high way like that.
Did I **** my self not doing the 350 booster and M/C? Do the 350 wheel cylinders take much more pressure than the 150 causing this?
The only reason I think not is because when I bleed the rear the pedal gets stiff when I do the front it gets spongy. Can't see any leaks. I'm limber enough and the trucks lifted enough so I can sit in it and hang out the door and look under the truck I don't see and leaks and my M/C isn't loosing any fluid
I have heard some guys say you gotta bleed it with the engine running but I've bled the brake on my f150 and my ranger with the engine off and everything was perfect
I used a C clamp and the old pad to compress the caliper. When I did the driver side it went slow like I was told and no fluid come out of the M/C. But when I did the passanger side I was a little too quick and fluid pushed out of my M/C. I saw it happen. The cap was on and it didn't force the cap off. I figured that meant I just push a crap ton of air into my system so I bleed all my breaks twice still no change.
Did I **** up my M/C when this happened?
Is it because of the 350 cylinders in the rear?
Do I just need to bleed it with the engine running?
Added a new (not reman) F350 m/c and no difference
Old February 4th, 2018, 06:22 AM
CharlieM's Avatar
CharlieM CharlieM is offline
sounds like you went in the right direction I would think that air is some how still in a line more toward the back. IDK. I never used a bleeder. I do a gravity bleed one at a time.
My .02$
Charles M
2002 F350 XLT 4x4 5.4 Auto
2000 Ranger 4x4 4.0
86 F150 4x4 auto 5.7
Old February 4th, 2018, 12:23 PM
Liked 113 Times in 109 Posts
I'd recommend you bleed with the engine running so the booster can do its job.
CharlieM , glc , harrison28 , Inside Man , JSoko , Longbeach4x4
1978 Brake Pedal Assembly inspector 1948-1983 Ford F100
3 February 20th, 2014 12:56 AM
STIFF gas pedal blueford 1992-1996 Ford F150
3 November 15th, 2013 06:16 PM
hissing noise coming from brake pedal malvarez58 Ford Expedition 4 September 26th, 2013 10:22 PM
Mazda drops the B-Series truck from its lineup Bates88 Mazda B Series
3 March 25th, 2011 03:59 AM
City Drops Lewdness Charge Against Woman, 81 BigT67 General Discussion
0 August 6th, 2009 11:09 PM
brake , drops , floor , pedal , resistance
