Quantcast 1954 F100 relay on firewall? - Ford Truck Club Forum
Old September 22nd, 2018, 08:37 PM
Malibujoel's Avatar
Malibujoel Malibujoel is offline
Default 1954 F100 relay on firewall?
Hi all.
I have a 54’ f100 that has been converted by previous owner to 12 volt system. Jeri rigged at best. There’s a 3 wire relay that looks original in engine compartment attached by 2 screws on passenger side firewall. See pic. I started to trace the wires. One was going towards a 12v voltage regulator attached to inside of right fender. Another wire going toward under dash and another wire was cut.
Is this relay the original 6 v voltage regulator? If its not the 6v regulator does anyone know what it is. I opened it up and it has 1 spool inside with some contacts.
Thank you.
Last edited by Malibujoel; September 22nd, 2018 at 10:53 PM. Reason: Trying to get image to show in post
Old September 22nd, 2018, 11:47 PM
If you are trying to attach an image, it has to be less than 100k in filesize, and less than 1280x720 pixels.
The other option is upload it to a photo sharing site, and use the insert image icon.
49 Effie , 56BigWindow , Booger , Erick , glc , harrison28 , justridinaround , Malibujoel
1954 B500 chassis magnakansas Auto Parts For Sale
0 August 17th, 2018 03:03 PM
1954 f100 Craig M 1948-1983 Ford F100
2 July 9th, 2018 10:08 AM
Firewall coolant leak? JCruz 1973-1991 Ford F150
12 September 3rd, 2013 07:44 AM
Weatherproof relay box BigBlue79 Garage Talk: Electrical & Lighting 5 March 8th, 2013 08:34 AM
Fuel Pump Relay Ridgerunner Garage Talk: Shop Class 101 6 March 26th, 2012 06:21 PM
1954 , f100 , firewall , relay
