Quantcast Magnaflow Dual Exhaust for 09 F150 - Ford Truck Club Forum
Old September 18th, 2009, 06:00 PM
Default Magnaflow Dual Exhaust for 09 F150
Now available for the new 09 F150's:
FORD TRUCK F-150 Stainless Cat-Back System PERFORMANCE EXHAUST
MSRP: $729.32
PART #: 16463
YEAR: 2009
DESCRIPTION: 4.6L and 5.4L, Crew Cab/Extended Cab, 66in, and 78in. Bed Lengths
5 x 8 x 18in. Dual Outlet Muffler, 3/2.5in. System, Dual 3.5in. Polished Tips, DUAL SPLIT REAR EXIT
SOUND_CLIP: No Media Clips Available
DYNO RESULTS: No Dyno Sheets Available
INSTALLATION: Install Sheet
CHECK INVENTORY: Check Availability
Additional Information
Material: 100% Stainless Steel
Tubing O.D. Size: 3/2.5in.
System Type: Cat-Back
TIP O.D. Size: 3.5in.
TIP Quantity: 2
Single/Dual: Dual
Exit Position: Rear Exit
Features and Benefits: Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last.
Magnaflow makes a nice throaty exhaust, especially under load.
BATES
Banks & PHP Powered
Old September 19th, 2009, 01:49 AM
Be nice if they had the set in 2 inch or 2 1/4 inch. I'll close my mouth and open my ears to the motor masters in here about motors an stuff but here's my two cents.
My 2001 GMC had a 4.8 (redesigned GM 283) factory OEM exhaust for a little while until i could afford to get a better exhaust. My goal was to improve mpg, power, torque and sound. It had the factory Y-pipe to a OEM single baffled exhaust muffler and out the the passenger rear.
I installed a 3inch Magnaflow with duals using 3 inch pipes and lost a lot of low end power. It also sounded like crap and to be honest a young kids rice burner on drugs with his ear closer to the ra-did-io speaker than anything resembling brains. Yeah I know you seen the camry in my garage but its late and im the only one on here on a friday night. i gots no life!
I ended up taking out the dual muffler and did single in single out Magnaflow 2 3/4 in/out to get my low end back. It had good power, great sound and i could get great mileage when i kept an egg between my foot and the pedal. Just wasnt enough engine power to do it with 3 inch duals and i didnt have the money or desire to mod out the motor. Doing an engine mod woulda defeated the purpose of saving money.
What makes me wonder is the F150 4.6 motor is not much more then a better totally redesigned 289 motor. The 5.4 motor is basically a 330ci and it might be ok with 3.5 system but if i were the mech that wanted a satisfied customer i'd have to recommend a smaller set of exhaust pipes on the 4.6 motor.
That said, with a dual 3.5 inch open flow muffler like the magnaflow it might be better to run two 2 inch or 2 1/4 inch pipes out with a set of 10 inch 3 inch black chrome tips at the ends.
Might be interesting with some dyno numbers?
Old September 20th, 2009, 07:51 PM
That kit is not true dual!
Old September 21st, 2009, 12:00 AM
Just cat back.
BATES
Banks & PHP Powered
beersnw27 , ericspainter , Jendiump , Julin , KeithFoult , maddawg99 , Shanehib , t3ob17
MagnaFlow Exhaust Installation MOTORZ TV MOTORZ TV 3 March 30th, 2011 08:50 PM
New Release by Banks > Monster Dual Exhaust Bates88 2009-2014 Ford F150
5 March 21st, 2011 09:09 AM
Truck U: 2 ˝ Dual Cat Back Exhaust TRUCK U TRUCK U 0 May 5th, 2010 12:38 PM
Custom Stainless Cat Back Dual Exhaust RedHot150 Garage Talk: Engine & Drivetrain 10 April 24th, 2010 10:57 AM
Magnaflow exhaust installation MOTORZ TV MOTORZ TV 7 July 21st, 2009 01:58 PM
dual , exhaust , f150 , magnaflow
